03-08-2009, 10:16 AM | #1 |
Need Help M/C demensions- Disc/Drum
I've read a thread on here where it was stated that the front chamber of the M/C is larger then the rear. It makes sense as the capacity would need to be more as the pads wear, and the bore is larger on the disc than the wheel cylinder. I don't doubt this, but my chambers are the same size.
When I bought the new M/C I held them side by side and everything looked the same, that does not mean that the PO didn't change it before me...so, my question is this, can someone verify the actual demension of the front chamber of a M/C with a disc/drum setup from a '72. I don't want to go back to the supply house without some sort of ammo. Thank You for anyone taking the time to help me out...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
03-08-2009, 11:16 AM | #2 |
Re: Need Help M/C demensions- Disc/Drum
Here's a couple quick pics. If you need something else let me know.
03-08-2009, 01:05 PM | #3 |
Wow, what a difference...as I suspected, the PO changed it to the wrong M/C. Thanks for the speedy response, now I have to take it apart and go back to the parts house
Thanks for taking the time
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-08-2009 at 01:13 PM. |
03-08-2009, 01:28 PM | #4 |
No problem
03-08-2009, 01:34 PM | #5 |
Could I bother you for another demension? Center to center on the brake line holes, I'm concerned the new brake lines may be differant
03-08-2009, 02:32 PM | #6 |
These ok?
03-08-2009, 07:03 PM | #7 |
Eat My Rust
My disk/drum MC has different sized reservoirs as well. All disk/drums setups are like this now days.
03-08-2009, 07:41 PM | #8 |
Eat My Rust
03-08-2009, 08:39 PM | #9 |
Perfect...Thanks again, won't bother you anymore.
That's what is great about this board, information, and good guys willing to share it
