03-08-2009, 10:30 AM | #1 |
anyone made their own blocks for leafspring rear
I was wanting to put in a 2 in. lowering block on leaf spring rear,axle is flipped already.The aluminum ones crack after awhile I was told,so was wondering if someone made their own out of steel tubing and what they used for pins
03-08-2009, 10:51 AM | #2 |
The One And Only !!!
Re: anyone made their own blocks for leafspring rear
Hmmm, Seems if they did there wouldn't be tons of manufacturers making/selling them. They are torqued tight between the perch and spring with the U-bolts, About the only way I know of for one to crack under normal driving is if the U-bolts loosen or are not tightened well enough. Even then I've never heard of one cracking but that's just me.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
03-08-2009, 11:08 AM | #3 |
Happy to be here
It should be easy to do, but I have never heard of blocks cracking.
03-08-2009, 12:29 PM | #4 |
Old Heap Driver
I banned the cast aluminum blocks when I was responsible for the rules at a local circle track. Too many of them were failing. The billet aluminum (solid) blocks had zero failure.
For street use I’d have no problem at all using billet aluminum blocks. Matter of fact I have 2” blocks on my truck now. To answer your original question, yes you could build them out of steel tubing. I've seen guys do just that. They used a cut off section of grade 8 bolt (the proper diameter) welded to the block as a locating pin.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
03-08-2009, 06:33 PM | #5 |
I have car A.D.D.
You could shackle it too. Just another option.
03-08-2009, 11:15 PM | #6 |
Sb 400 club
To lift we used square tubing and made locator pins. Worked fine on 4x4's and I bet the reverse could be done in ur case.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
