Old 03-08-2009, 10:55 AM   #1
drbyrdman
drbyrdman's Avatar
1970 gmc dana 60 rear disc conversion
i thought i had everything to do a Dana 60 rear disc conversion. but it looks like i screwed up. i got a 3/4 ton front and pulled the discs and rotors to do a swap. the Dana 60 is totally different need what i read on line. the drums are held in place with two screws and the drums slide right off. any one know what disc i need to get. didn't see any that just slip right back on and use two screws to be held in place anywhere.
drbyrdman is offline   Reply With Quote
Old 03-08-2009, 10:57 AM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 1970 gmc dana 60 rear disc conversion
These guys can probably help you out.
http://www.blackbirdscustomtrucks.com/index.html
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-08-2009, 06:17 PM   #3
drbyrdman
drbyrdman's Avatar
never mine i got it done
Old 04-02-2009, 03:30 PM   #4
Garage Freak
Drbyrdman,
Mind sharing how you got it done? I need to do the same conversion.
Thanks!
Garage Freak is offline   Reply With Quote
Old 04-02-2009, 05:04 PM   #5
drbyrdman
drbyrdman's Avatar
took dana 44 rotors and install them on the rear. and i am getting some weld on brackets from ruff stuff to hold the calipers on.
Old 04-02-2009, 06:29 PM   #6
mr48chev
mr48chev's Avatar
Ok' where are the photos? So the rest of us can see what you did.
I've been tracking down pieces to use on my 71 but still need the caliper brackets.
