Firefighter
Ok I have a 1970 Chevy on a 1981 Chevy 4x4 frame, the frame is cracked in a couple of spots and the cab and body are not mounted the best in the world, and I also have a 1970 2wd Chevy frame that I would like to use for the conversion, so I already have all the parts. I would also like to do something a little differently, I would like to keep the coil spring rear end. So my questions are,
#1 If I keep the coil spring rear end and flip the axle how much lift will it have? #2 I am looking at the DIY4X FGB52 kit for the front, if I get it, will it lift the front any or not? #3 In using the FGB52 kit for the front, will the 52" springs off of the 1981 fit? ![]()
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 03-13-2009 at 08:58 AM. |
![]() Join Date: Nov 2006
Re: 2wd conversion questions
Flipping the rear axle should gain you 6-6.5" of lift. You will probably want to do something with your track bar, either lengthen it or make some sort of bracket to put it back at the right angle other wise your rear end will be shifted to the driver's side.
I don't know anything about the DIY kit but I think a few members here have installed it so I will let them chim in. I can tell you that the 2wd frame rail has a dimple on the drivers side front where the shackle would mount, this will need to be cut out and boxed in some how.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris Last edited by desertrat; 03-08-2009 at 08:13 PM. |
#3 | |
#1............anwered above
#2.............yes about 4-5" if your using factory rears #3.............yes
My builds 69 stepside.......2wd to 4wd http://67-72chevytrucks.com/vboard/s...d.php?t=330675 and the new 66 http://67-72chevytrucks.com/vboard/s...d.php?t=302321 |
Firefighter
Thanks, for the answers guys!! Is anyone using the FGB52 kit, and if so how do you like it?
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Firefighter
I have another question also, will the 81 engine cross member work on the 70 frame?
check out my 69 build thread in my signature.........the fgb52 kit is great.
Firefighter
Nice, I like the looks of the kit!!
Firefighter
Will the engine cross member work?
I helped my buddy with this build.
Sold...1965 Chevy 3x4 ton 4x4, short bed step side |
Firefighter
This is my 4x4 I am wanting to use for the project
Firefighter
What I am hoping to acheive.
#13 |
Firefighter
Will the crossmember work?
#14 |
Edit to fully answer your questions:
1: Yes, the 52" (1981) rear springs will work in the front with the DIY4x kit. Tell Kert I said hi!. 2: Yes, the engine cross member will work, as will the trans/transfer case one. Heck, your driveshafts will probably fit... might be able to squeak em in by moving the front axle with the different holes on the DIY4x kit. Last edited by FormerMember; 04-02-2009 at 03:25 PM. |
#15 |
Firefighter
Awesome Thanks Grendel!!!!
