Old 03-08-2009, 01:40 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
How to convert to R134A?
Well, my trucks A/C needs charging, I have to convert it to charge it. How do I do this? Also, what is the commercial refrigerant that has the same compound as R134A but i colder?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-08-2009, 07:36 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: How to convert to R134A?
Try Freeze 12. You have to replace the accumulator, orfice tube, pressure switch and oil. A new pressure switch is required for R134. I'm not so sure on Freeze 12. Open up the system. Flush the system using a can of A/C flush through the lines and condensor. Or use isopropyl alcohol. Remove all the oil from the compressor. Refill using the correct oil. Replace all the o-rings on the lines. Put a vacuum pump on it. It should hold vacuum for 30-45 minutes. Refill using the proper guages.
Here is a nice write up for our trucks. http://www.chevytalk.org/fusionbb/sh...hp?tid/168431/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-08-2009, 07:49 PM   #3
thirdstreettito
Resident of Here
Thanks. I dont know what most of what you said is. The refrigerant I am talking about is something like 908 or 906 or 904, I cant remember which one, it is exactly like R134A but colder.
~Bradley~
Miss having a truck
Old 03-08-2009, 08:51 PM   #4
AceX
>130dB Moderator
AceX's Avatar
Just run 134. Its cheap, and available. I did the conversion in my truck (well, I had a shop that is very experienced with the conversion do it.) and I don't regret it one bit.
Besides that, I'll be doing a motor swap sometime this year or next year, and the compressor on that motor is set up for R134a. All I will have to do is make some new lines and off I go.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 03-09-2009, 07:20 PM   #5
Strodder
Daring to be Different
Strodder's Avatar
R-134A works with higher pressures. Any weak points in your A/C system will leak. Especially your old hoses. I would stay with the R-134A because they it is inexpensive and easy to get. Most A/C recycling/Charge Stations have both. There is a lot of cross contamination out there with so many different kinds of Freons. And do take it to a professional. You'll get the best results, if they know what they are doing.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
