![]() Join Date: Nov 2000
Heater Hose-Dual Feed Carb Issue
How do you all with dual feed carbs and a heater hose that taps into the intake handle the plumbing? I installed a dual feed carb last year and ended up bypassing the heater for now, but I want to do it right. It seems if I could find a 5/8" barbed elbow that would go into the intake instead of the straight barbed 5/8" fitting; would be the easy fix to prevent the fuel and heater hose lines to cross paths, but I can't seem to find one. Any ideas? Thanks.
Pics would be very much appreciated! Last edited by 72step; 03-08-2009 at 01:58 PM. |
Re: Heater Hose-Dual Feed Carb Issue
any auto parts store should b able to get a 45 or 90 fitting even a good hardware store should have it too
![]() Join Date: Dec 2007
Not sure if you want chrome or not, but there are Chromed Brass 90's on eBay. I have bought them before.
put a inch or 1/2 inch carb space on it and problem sloved. what i had to do. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
