Old 03-08-2009, 11:37 PM   #1
eric67m
eric67m's Avatar
Carpet VS Vinyl rubber flooring
What is a better floor covering between carpet and rubber vinyl. I like the idea of not having carpet but it seems like rubber could keep moisture underneath it and promote rusting on the floors.
Both of my trucks have had rubber and have ben completely rusted out.
What have other people found in the trucks that they have worked on.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 03-09-2009, 12:17 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Carpet VS Vinyl rubber flooring
First off I would recommend repairing any leaks that would allow water in, then you should be able to use whatever you want.... I prefer rubber mats in 4x4's and work trucks and carpet in the cruisers...
LockDoc
Leon
Old 03-09-2009, 12:32 AM   #3
eric67m
eric67m's Avatar
Both of my trucks were completely gone when I got them. One of my trucks was a colorado transplant and then became a washington "farm truck". I am replacing the cab with a pretty solid one. Just looking for other opinions.
Old 03-09-2009, 12:43 AM   #4
Andy4639
Old member
Andy4639's Avatar
Carpet will hold water too if it gets under it.
The key is to get all the cab seems and holes fixed before you install either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-09-2009, 12:59 AM   #5
72blue
72blue's Avatar
I have had several early broncos all of which had rubber or vinyl and the rust out result was a half and half. I was torn between the two and decided to go with carpet in my 72, black at that. It is going to be more of a cruiser though. I would do rubber if it was going to be a DD. Just my view.
James
James
72blue is offline   Reply With Quote
Old 03-09-2009, 01:24 AM   #6
spinning wheels
spinning wheels's Avatar
After ripping out the yellow shag carpeting the PO installed, I went with rubber . Mainly because as stated, wearing muddy boots. I did install a sound deadening mat underneath the rubber. Then again, I had a Jeep Grand Cherokee 4X4 with carpeting and I just installed rubber mats from wallymart and they worked great too.
If I had to do it again...... I would go the cheaper route
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-09-2009, 09:35 AM   #7
68gmsee
Active Member
68gmsee's Avatar
In my years of looking at old cars and trucks in junkyards and privately owned, I found the rust issue is about the same. Since carpet is porous, you stand as much chance to get moisture trapped underneath it as you do a rubber mat. You just have to be diligent and keep rust out on whatever you choose.
My old GMC had rubber and no rust underneath it. And since I use my truck out in the country roads, I'm staying with it. I'd go with what you think you can live with and what you can spend on it.
68gmsee is offline   Reply With Quote
Old 03-09-2009, 03:57 PM   #8
eric67m
eric67m's Avatar
price seems about the same between the two. I was leaning 85% to the rubber and I think I am all the way there now. Thanks for everyones input.
