![]() Join Date: Nov 2007
Dash Light Problems
Im having a weird problem. When i press my brakes, my dash lights come on. Now this doesnt happen all the time, so i figure somethings loose. Any ideas on what to check, Thanks Kyle
its all about the +6 inches
Re: Dash Light Problems
a cheap quick check, would be to replace both tail light bulbs.
Active Member
![]() Join Date: Jul 2007
That's one I haven't heard of before. Gonna be hard to isolate since it only does it occasionally, but another thing you could do is to disconnect the brake lights switch and see if it still does it. You can isolate part of the wiring that way. You would have to do it in a place where having no brake lights would not cause a problem. Maybe a large parking lot.
And, while you're under the dash, look to see if there's any wires rubbing on the pedal parts. Last edited by 68gmsee; 03-09-2009 at 05:40 PM. |
Gone to greener pastures
![]() Join Date: May 2007
Check your grounds.
I've seen some loose/bad grounds do some really, really weird stuff.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
your bulbs have 2 filliments, one for parking lights, one for brake/turn signal. If the filliment for the brake/turn signal blows, and is hanging by one side, and dangles down to the parking light filliment, then when you hit the brakes, and energize the remains that are sitting there making contact to the parking light side, then when ever you hit the brake, the parking lights will get powered up to include, the dash lights.
Ok i put some new tail light bulbs in, hopefully this will fix it
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
You have the wrong bulbs in the brake lights. Most likely anyway.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
GOOD POINT... did you get 1156, or 1157? They take the latter
I agree with longhorn to a point but i bet its a taillight socket. Fords are famous for it. What happens is the socket gets wet and grounds out causing a short then when you hit the brakes it backfeeds through the fusebox. Took me awhile first time i ran across that one.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
I put 1157 in, is that right?
at our shop, we have found that tail lignt bulbs are the number one cause of malfunctions, they cause a feed back thru the sytem when malfunction.
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
#13 |
cool... 1157 is correct.
#14 |
Well so far no problems with the new bulbs, it rained 4 inches last night and it didnt seem to effect them when i drove to work this morning
#15 |
Great!!! Hopefully it'll stay that way. At least it was a cheap easy fix!!
