03-09-2009, 03:11 PM | #1 |
GM ONLY BABY!!!
How to change sunvisors?
I purchased some new sunvisors from Classic Parts of America and I need to know the easiest way to remove the old mounting brackets and install them into the new visors. I'm guessing just pull hard, but I don't want to break anything. How are they then installed into the new visor?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
03-09-2009, 03:30 PM | #2 |
member #16
Re: How to change sunvisors?
I just twisted up and down while pulling them off.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-09-2009, 04:20 PM | #3 |
Twist-N-Pull.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-09-2009, 05:38 PM | #4 |
Old member
That's right twist and pull. They will come off. Make sure you aren't doing facing the rear veiw mirror or it will come off too! Don't ask!
03-09-2009, 06:59 PM | #5 |
GM ONLY BABY!!!
That's what I thought. I guess I just shove the bracket into the new ones then, right? Thanks!!
03-09-2009, 07:02 PM | #6 |
You are correct!! rinse and repeat.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
