Headlight issue + new guy
Hi Guys
This is my first post on this great site! Theres nothing like a group of people with a common love for these beautiful trucks helping each other. I have a 69 c10 LWB truck that I bought in 2006. its got a 307 I beleive that the PO said he rebuilt before I bought it. it ran great while I drove it but I ended up parking it sometime in 2007 because of gas prices and I cheaply picked up a acura with heat, ac, and a transmission with over drive. Recently the acura was stolen and with gas prices down and me working from home im not driving as much, so i thought its time to get the ol truck running again. And Dam I miss driving it! its not much too look at right now but it sure is fun! Anyway I put new gas and fluids in and it fires right up! I go to take it for the maden voyage and notice the headlights dont work. The running lights, blinkers, dome, and brakelights all work but the dashlights flicker and work intermittently. I checked all the fuses and they are good. So I jump on the forum and do some searching and come up with the headlight switch. I put a new switch in and the dashlights work great now but still no headlights. More searching on the forum lead me to testing some wires and thats where im stuck and I hope you guys can point me in the right direction. The headlights work when connected to the battery but the wires running to them have no power. The Dimmer in the floor has power on the lt blue wire but nothing on the tan or lt green wires. and thats where im stuck. is my dimmer bad or is the problem further up the line? Ultimately I want to do the headlight relay upgrade but from what I understand I need to see power on the tan and/or lt green wires correct? Thanks in advance for the help and thanks for making this site such a great place! Tim |
Can't ReMember
Re: Headlight issue + new guy
I've had my truck for over 30 years and twice I had the headlights quit. Both times it was the dimmer switch. Replaced it and all was well.
Welcome to the forums
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
![]() Join Date: Jul 2003
Usually the floor mounted dimmer switches are the culprit. It is entirely possible that both bulbs are blown, but not likely.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Grandpa in the rustmobile...
try teh dimmer switch mine went out too 7 bucks to replace at autozone etc
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Pull the plug on the dimmer switch and jump between the light blue wire and the tan one or the light green one, and if the headlights work then the dimmer switch is bad. There are no grounding issues with the dimmer switch to worry about.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#6 | |
Thanks for the welcome guys and the information!
I was leaning towards the dimmer switch being the problem until now.. Quote:
I also hooked up one of the headlights directly to the battery and it worked. So I know at least one of my headlights is good. So from what I can tell from the wiring diagram, if I jump the dimmer switch plug and nothing happens that means there is a break in wire between the dimmer plug and the headlight? Or a possible ground issue? That is of course if I am reading the diagram correctly. Thanks again guys! |
RIP BigDaddyDave ~7-23-09~ You will be missed~
Welcome to the board from NC!
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
#8 | |
Old member
VetteVet,
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
