Old 03-09-2009, 03:58 PM   #1
oldgmc
oldgmc's Avatar
Installing a rear tank sending unit question
I will be installing a rear tank (75 Blazer or similar) In my 79 K35. I have a great link someone here sorry I forget who sent it. Question is my original set up had 2 - 20 gal side tanks had a 3 outlet sender and the vent was on the tank next to the filler. Do I need a 3 or 4 outlet sending unit with new tank. The truck being a one ton does not need emissions like a canister ,egr or cats. From what I can tell the blazer tank has the vent line on the sending unit.
The sending unit is expensive so I want to get the correct one
oldgmc is offline   Reply With Quote
Old 03-09-2009, 09:29 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Installing a rear tank sending unit question
You only need 3 on a carb setup. Fuel, return, Purge
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-10-2009, 07:35 AM   #3
mainermikeyd
mainermikeyd's Avatar
Oldgmc could you take some pics of your install an such, I also am considering to install a blazer tank, would be interested in your progress, THANKS
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 03-10-2009, 09:11 AM   #4
Captkaos
Captkaos's Avatar
This is my how-to for the Blazer install I did about 10 years ago.
http://www.captkaoscustoms.com/blazertank.html
Chris Lucas
1973 Chevy C-10
Captkaos Customs
