Old 03-09-2009, 07:13 PM   #1
4DSEVEN
4DSEVEN's Avatar
Help! Chev S 10 rearends don't measure up??
I have found two chevy s 10 rearends. They are from an 88 & 89.
I am told they measure 48" & 52" backing plate to backing plate.
From what I have read and searched it is my understanding that I need between 58-62".
I thought the S-10 rearend was good?
I haven't purchased one yet so I still have options.
Can someone shed some insight.
I have the link showing the various vehicles but am I looking at the wrong measurement using back plate to back plate?
4DSEVEN is offline   Reply With Quote
Old 03-09-2009, 07:18 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Help! Chev S 10 rearends don't measure up??
not sure about first gen S10's...but the second gens are
2WD rear assemblies are 54.5" wide
4WD rear assemblies are 59" wide
ZR2 rear assemblies are 63" Wide
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-09-2009, 07:27 PM   #3
iokua80
iokua80's Avatar
For the s10 swap it is recommended to either run a 4wd s10 rear end cause it is wider than a 2wd. Or you can run a camaro rear end like I am. If you run a 2wd you'll have to tub the bed and do some other cutting that I'm not sure of. Best to make sure you are running a 4wd or camaro.
Later,
Josh
iokua80 is offline   Reply With Quote
Old 03-09-2009, 07:45 PM   #4
4DSEVEN
4DSEVEN's Avatar
Would you happen to know if this is backing plate to backing plate or drum to drum?
I'm thinking that maybe it is drum to drum? Then the one I have at 52" would likely fit. Yes? No?
Both of these are 4x4.
The truck is at my buddies shop otherwise I could just measure what's on it.
Old 03-09-2009, 09:00 PM   #5
entourageguy
Yellow truck club
entourageguy's Avatar
I think it's mounting surface to mounting surface.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-10-2009, 03:37 AM   #6
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
what ever you do get the wider one. i just got my rear end (89 s10 4x4) and it is still not enough, I'm going to have to get wheel adapters also, but i also want to run a wider rear tire.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 03-10-2009, 06:43 AM   #7
4DSEVEN
4DSEVEN's Avatar
Nick would you happen to recall what the measurement was?
Old 03-10-2009, 07:12 AM   #8
63 & 64 Bowties
and a few others
I've got both 2wd & 4wd first gen S-10 rears if you need any measurements.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 03-10-2009, 12:58 PM   #9
4DSEVEN
4DSEVEN's Avatar
Ok the box width is 50" and my axle is 52. Does this mean I will have to tub the box? Or can I use spacers?
Also am I going to have a difficult time finding rims to fit?
Should I try to locate a wider axle?
Any help is appreciated.
Old 03-10-2009, 01:31 PM   #10
b00sted
b00sted's Avatar
I am going with the ford 8.8 axle in my truck out of the 95 and up explorer. 59" disk brakes, posi and 3:55 gears for a whopping $150 from the local scrap yard...
i am going to go with the ford pattern also ont he front rotors so everything will match...
If the rear end is to short you are going to have to back half the truck and move the frame rails in... Plus the wheel tubs...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-10-2009, 06:38 PM   #11
Thadious
I've got the 4x4 rear setup in mine... and yes... it's 52" from the inside of the backing plate to the inside of the opposing one... so it ends up being about 59" or so from drum to drum mounting surface. The 2wd ones are 48" (inside measurements).
Cheers,
Ted.
Thadious is offline   Reply With Quote
Old 03-10-2009, 11:56 PM   #12
4DSEVEN
4DSEVEN's Avatar
Cheers,
Ted.
Ted, Did you end up tubbing your box or is an inch on each side ok?
Thanks.
Mark
Old 03-11-2009, 12:04 AM   #13
Thadious
I haven't had the opportunity to fit a box to mine yet... just wanted to confirm the actual measurement sizes on the 4x4 rear. I just went out to the shop and measured the backingplate distance.
Cheers,
Ted.
Old 03-11-2009, 05:01 AM   #14
iokua80
iokua80's Avatar
Thanks.
Mark
I did end up having to put a small tub in because I had 20x8.5s. I think it's about an inch wide. I can take a pic of it if anyone wants to see it. Aired all the way out I rub on the outer fender too.
Later,
Josh
Old 03-11-2009, 06:39 AM   #15
4DSEVEN
4DSEVEN's Avatar
Josh if you take a pic that would be great. Also, did you make your own or buy your tubs?
Youngrodder had posted this link before and I may end up ordering from them.
http://dancarpenters.com/tubb.html
Mark
Old 03-12-2009, 12:08 AM   #16
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Ok, so i started to think about this today, and found this thread. I've spent some time, and based on my measurements, this is what i've come up with.
This basically means that a 52" - 56" rear would work for me. This assumes i tub it to the frame rail and that wheels have a 5.5" backspace.
here are the tires that i'm estimating will work:
* used this site for the tire dimensions: http://www.wheelsmaster.com/rt_specs.jsp
Also, based on my calcs, with a stock setup (no tubs) you need the 59" rear, but can only run a 6" wide tire. This assumes 1" of space on both sides of your tire, on both sides of the truck.
uhg, my head hurts.
IvelDesigns is offline   Reply With Quote
Old 03-13-2009, 03:50 AM   #17
nickp51chevy
4dseven,
i haven't measured my axle. but i will and i'll get back with you on it. don't go cuttin' up your bed and frame yet. i'm not going to tub mine and i'm going to try to run 10" wheels. i'll take pic's and let you know what i end up doing.
Had;
Old 03-13-2009, 12:28 PM   #18
4DSEVEN
4DSEVEN's Avatar
I have gone ahead with the S 10 rearend and expect to have it in my posession this weekend.
From all the information I have read and through everyone's on going discussions I believe I am on the right track.
No plan to tub unless I have to, but will cross that bridge once I get there.
Thanks to everyone for their input.
Old 03-13-2009, 02:18 PM   #19
nickp51chevy
my rear end looks to be 53" b/p to b/p. as you can see in the pic i just need to get a wheel spacer and I won't have to tub or cut anything.
Had;
