![]() Join Date: Feb 2005
NOS Trim Adhesion Question
Putting new NOS spears & wood grain Trim on my truck and some of the original adhesive tabs don't want to stick very well. Anyone know what to use to make it stick to the metal better. Thanks
Re: NOS Trim Adhesion Question
you want to rub the area where it meets the metal with wax and grease remover if the tape is bad you can scrape off the tape and get some new tape at your paint store
If that original adhesive is dried out I would take a razor blade and scrape it off and use 3M double face tape and just cut new blocks of it and place on the pads. You can buy it in a roll at any auto body/ paint supply store.
Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
Has anyone tried an adhesion promoter that ABS sells. I heard that might work.
#5 | |
Moderator
![]() Join Date: May 2007
I am in the process of putting trim back on my C-20. I have found that this is the best way to do it if you have the original plastic mounts on your upper trim. On the lower trim I am using the factory metal clips, and they work the best for pulling the trim in flush against the body. |
I found that out last night. The new clips hold the molding out farther than I like it so I used my old plastic clips with new 2 way tape and they make the molding fit tight and look lots better in my opinion. The new NOS clips snap real easy if you bend them a little to much. Thanks
