03-09-2009, 08:08 PM | #1 |
Points ignition Questions
Is the condenser attached to the coil the same condenser used inside the distributer????
Which side of the coil does it go on (positive or negative)??????
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
03-09-2009, 08:13 PM | #2 |
Son of a gun
Re: Points ignition Questions
Yes, another of the same condenser will work. All the condenser on the coil does is surpress electronic noise. You really do not need it unless you are still using your AM radio. I believe it goes on the negative side.
Bill BEATERS ARE NEATER |
03-09-2009, 08:15 PM | #3 |
Nothing to see here.....
are you talking about the condenser "looking" pice that attached to the coil bracket? if so, then you are looking at the noise suppressor for the radio.
the condensor that's contained in the distributor will be connected to the negative post on the coil. ^^ looks like busted knuckle beat me to it!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 03-09-2009 at 08:16 PM. |
03-09-2009, 08:36 PM | #4 |
thanks guys, I should have thought about that
03-10-2009, 04:35 PM | #5 |
The radio suppreser gos to the pos. side of the coil with neg. ground.
03-11-2009, 12:38 PM | #6 |
It's a catastrophic success.
The condenser actually helps prevent the points from arcing which would shorten their life.A noise suppressor is iirc is mounted on the coil + between the ign switch and coil
