03-09-2009, 09:47 PM | #1 |
67-69 4x4 motor mount towers.
Does anyone have a pic? I'm trying to compare it to the 63-66 towers. I need a set, and the 63-66 ones are impossible to find. Here is a pic of the 63-66.
03-09-2009, 11:57 PM | #2 |
60-66 Nut
Re: 67-69 4x4 motor mount towers.
I can get you a pic of a '69 tomorrow. The '67 and up are different in that there is a crossmember that ties both sides together. However they use the same motor mounts.
03-10-2009, 12:50 AM | #3 |
Truckin' Krazy
Heres a pic of one still in the truck, pretty big difference from what your looking for.
Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
03-10-2009, 06:57 AM | #4 |
Yes, it is alot different. Thanks for the pic.
03-20-2009, 11:30 AM | #5 |
Is this one available?
03-20-2009, 12:49 PM | #6 |
If Toms isn't available, I have a very nice one sandblasted, epoxy primer & urethane top coated ready to install.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-20-2009, 12:56 PM | #7 |
Cool! I'll let you know. I found a guy that put one in his 64 4x4, and it was a bolt in. After drilling the holes of course.
03-20-2009, 02:01 PM | #8 |
Truckin' Krazy
That one is for sale $50 + shipping. let me know if you need it.
Tom
03-20-2009, 04:04 PM | #9 | |
By rondavid, shot with E8800 at 2009-03-04 here is that picture of the 67 motor mount crossmember in my 64 that top picture of the 4x4 stand is mine also( you must have got it from Pershe's site) a nice fellow from Minnesota sent me mine, just cost me postage. he is a member here to. has a big white 1 ton panel 4 x 4 ron this motor mount steup makes more sense especially if you drop the bellhousing crossmember for a rear trans mount or automatic as the only real support that you then have is that little rad support crossmember in the frt. that bellhousing crossmember also served as part of your front spring rear hanger. you have to leave part of it there). this why it is good to have that motor mount crossmember. I could have left my bellhousing one in as I installed a t5. I did have one of those complete p/glide crossmembers which I put in for the rear trans and seeing that i only have a 10" d/shaft to my np205 it solidifies the mounting back there ron Last edited by padresag; 03-20-2009 at 04:16 PM. |
03-21-2009, 10:21 PM | #10 | |
Thank you very much for the info!! |
