Old 03-10-2009, 12:01 AM   #1
tekno62
E brake problem. 72 chevy
When I got the truck I had to redo all the brakes.
My question is when I put the brake petal down it doesnt spring back up when I pull the handle.
any ideas.
tekno62 is offline   Reply With Quote
Old 03-10-2009, 06:34 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: E brake problem. 72 chevy
I have the same problem with my '71 GMC. I find that the pedal will come up more if I hold the release handle out longer. Or I'll tap it up with the toe of my left boot.
Supposedly there's a little spring inside somewhere. I couldn't find it. I've shot WD40 at it blind with not much effect.
It's worse when it's cold out. In hot weather, it pops right up.
Go figure.
Old 03-10-2009, 12:03 PM   #3
northerngmc
northerngmc's Avatar
I was having the same problem. I replaced the e brake cable on the left side where it goes into the backing plate and it is better. The cable has a spring on it and this is what I believe pulls the pedal back up.
I have purchased the right side on as well but have not installed it.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-10-2009, 03:37 PM   #4
cdowns
cdowns's Avatar
anybody ever think of lubricating the 40year old cable so it would move freely?
Old 03-10-2009, 08:08 PM   #5
northerngmc
In my case the cable moved freely the spring tension was long gone and therefore would not fully release the cable. If someone has had luck by simply lubricating the cable I would be interested in hearing about it.
Blaine
Old 03-10-2009, 08:38 PM   #6
tekno62
I need to check
Old 03-10-2009, 09:47 PM   #7
Andy4639
Old member
Andy4639's Avatar
Upunder the dash looking up over the e brake pedal. It's not binding on anything there is it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-20-2009, 09:52 PM   #8
northerngmc
Have you had any luck with your e brake yet?
Blaine
Old 03-20-2009, 10:22 PM   #9
tekno62
Sorry - been working alot and when I have the time I forget or am doing something with the family
I work tomorrow and hope to check the truck Sunday.
Old 03-21-2009, 12:26 AM   #10
oldiron
Designated Grumpy Old Man
oldiron's Avatar
There is suppose to be a return spring on the pedal assy. Check again it my have broke or fallen off.
oldiron is offline   Reply With Quote
