03-10-2009, 10:06 AM | #1 |
500 c.i. caddy engines
I have six of these engines for sale. I would like to get $500 or best offer per engine.
03-10-2009, 11:11 AM | #2 |
Member #1049
Re: 500 c.i. caddy engines
That's quite a stash of torque you have there!!
Just curious, In your first picture on the lower right side I see what appears to be a Ford Boss or Cobra finned aluminum valve cover.. At first I was thinking a Boss 302 or 351 cleveland, but they do not have an oil pressure port on the back of the block.. does it happen to be a 429/460 Cobra? Or just a Cobra valve covered big block? |
03-10-2009, 11:22 AM | #3 |
that is a 351 cleveland that's hard to find nice motor. Thats for sale too!
asking $500 obo for that too. |
03-10-2009, 11:46 AM | #4 |
Future TOTM Winner
Somewhere Longhornman just got all kinds of excited
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
03-10-2009, 11:47 AM | #5 |
any of those a 1970 motor? are they from an Eldorado with the rear oil pan?
thx, Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
03-10-2009, 11:51 AM | #6 |
if these are all truly 500's....you should contact MTS in Apple Valley. They may buy all 6.
marty@mtscadparts.com
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 03-10-2009 at 11:51 AM. |
03-10-2009, 03:03 PM | #7 |
MTS would want them but unfortunatly for maybe $200 a pop.
03-10-2009, 03:31 PM | #8 |
Saving 1 truck at a time!
Does the Cleveland have the 4V heads? I suspect not since it has a 2-barrel carb but I had to ask.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
03-10-2009, 06:37 PM | #9 |
I posted them at MTS and could only get one guy to comment on them. These ford are foreign to me how would I tell if it has 4V heads?
03-10-2009, 10:06 PM | #10 | |
Member #1049
The 351C's had either 2V or 4V cast into the head between the intake and valve cover on one end or the other.. no real need to look since yours has a factory 2bbl on it they are 2V... the manifolds are not interchangable.. (well... they will bolt on... but there will be a BIG vacumn leak). |
03-10-2009, 11:52 PM | #11 |
Al, yes one is a 70 eldo with a rear pickup or sump but a guy from L.A. is buying it for alot of money. More money than I thought it was worth.
03-17-2009, 10:58 PM | #12 |
How much? It's worth more than 3K, if it has the right crank.
03-17-2009, 11:53 PM | #13 |
do you have any newer caddy motors? Need one for this STS.
03-18-2009, 12:10 AM | #14 |
grendel, yes the 70 caddy engine that came out of the eldorado has the right crank as I have been told.
03-18-2009, 08:18 AM | #15 | |
Have you been on the Caddy power board? Last edited by FormerMember; 04-02-2009 at 03:26 PM. |
03-18-2009, 09:02 AM | #16 |
Under Construction
Grendel, what's the board, seems like i need to start looking for caddy motors
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-18-2009, 09:11 AM | #17 |
03-18-2009, 09:17 AM | #18 | |
Here's where all the Caddy power nuts go. http://www.cadillacpower.com/forum/i...board,4.0.html Can you get me the casting numbers on the 72 motor? Block and heads? How many miles on it? Last edited by FormerMember; 04-02-2009 at 03:27 PM. |
03-18-2009, 09:38 AM | #19 |
What is the right crank? 472's have the same crank in that year. In all the caddy big blocks I have run, 71's and up 500 or 472 run fine on pump reg.
All the older higher comp. engines need better fuel or you have to cut the timing way back to avoid the dreaded spark knock!
1968 Chevy 4x4 307 4 speed |
03-18-2009, 09:40 AM | #20 |
Ill get that info tonight.
03-18-2009, 09:44 AM | #21 | |
Also, I have a 70 Caddy that runs fine on 89 octane. Last edited by FormerMember; 04-02-2009 at 03:27 PM. |
03-18-2009, 01:00 PM | #22 | |
All caddy motors are some of the best Big block power Gm put out. So please buy from Rick if you are considering this fine upgrade. Not trying to step on your sale Rick. I loved the 500 I had in my truck.
1968 Chevy 4x4 307 4 speed Last edited by GMC AMI; 03-18-2009 at 01:09 PM. Reason: info |
03-18-2009, 01:03 PM | #23 | |
10:1, stock. Sorry for the hi-jack. Last edited by FormerMember; 04-02-2009 at 03:27 PM. |
03-18-2009, 02:49 PM | #24 |
[QUOTE=GMC AMI;3204845]You would be at the cut off point at 10: 1 as far as pump gas goes. A big block will do a bit better than a small block with that compression ratio run on pump gas. The 472 1969 engine I ran had a higher comp ratio 11to one or 11.25. Too old to remember which. Pump gas has been going downhill for a long time!!! Still a better engine for a truck than most Chevy motors. Sorry Chevy guys but this is very true!
03-18-2009, 07:35 PM | #25 |
the right crank #'s end in 094. The book states the the '70 motor is 10:1 comp, but up to date testing puts it at 9.4:1. from a collector's stand point that is the crank to have, for $3000.... I don't know... the other cranks are strong as well only slightly less. the higher comp comes from the desirable 76cc heads. (904's and the newer 950's) engine HP rating (ways of testing) changed in 1971, that is the main difference for the HP drop in the '71 and newer 500's.
Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban Last edited by IAFF2407; 03-18-2009 at 07:38 PM. |
