03-10-2009, 08:14 PM | #1 |
front leafs
i have springs out of an 87 blazer that came on my k10, are these good springs to be running or should i replace them?
also is there anything that is different about these springs(like witdh, length) compared to the stock 68 leafs that they replaced? just trying to learn as much as i can, and also make sure that everything is safely done thnks nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
03-10-2009, 09:17 PM | #2 |
Re: front leafs
I believe the 87 are 47 inches long and the 67 to 72 are 44 inches long
69 Chevy 4x4 383 Power |
03-11-2009, 04:05 AM | #3 |
Re: front leafs
if you put them in the front you can get like 4.5 iches of lift i wouold leave them and just cut the hell out out of your wells
03-11-2009, 09:09 AM | #4 |
Re: front leafs
they are in the front, what would cutting the wells do? im not planing on doing that serious of off roading
03-12-2009, 09:47 PM | #5 |
Re: front leafs
how long are the sotck shackles for a 68 k10 suposed to be i measuered the ones that came on my truck are 6.5" long and are 1/4" think, i personaly think they are homemade wil put up a picture tomorow
what does puting a longer shackle acomplish? does it lift the truck? also is a 6.5" long by 1/4" thick a safe shackle or hould i replace them with ones from diy4x this truck is not going to be a serious offroader but it will offroad quite a bit and will need to be strong and safe as it will also be my daily driver thanks nate
03-17-2009, 12:54 AM | #6 |
Re: front leafs
i think it should be safe for mild wheeling and driving because diy4 has them 6in but it's 3/8
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
03-17-2009, 12:59 AM | #7 |
Re: front leafs
03-17-2009, 10:14 PM | #8 |
Re: front leafs
i decided to replace them with 6"ers from diy4x being as when i took them off and cleaned them up i found stress fractures
03-17-2009, 11:26 PM | #9 |
Re: front leafs
I'm glad you checked it then you changed it because you found something wrong and didnt wait till it broke
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 03-17-2009 at 11:28 PM. |
