Old 03-10-2009, 08:27 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
how do i tighten parking brake
okay,,,well i have NO parking brake....
crawled under there but didnt really see anything and wanted to go drive around, so i did lol....but how do u tighten it..like to get it working properly cause ive needed it a few times already..but i ditched tightening it and deicded to cruise around and take a few pics and have a chat with an older fella that had a 1960..some kinda mopar golden commander? i think thats right....it was REALLY nice...i stoped because he had a 68 gmc and a 71-72 swb lowered with big drag slicks on back that doesnt have a motor...i forgot to ask him if he'd sell it or part it out
(for disc brakes lowering spindles) well heck for the swb maybe even!
didnt get alot of pics of other peoples stuff but heres a few i took
well i'll try to get pics later they dont wanna upload...lol
how do i tighten my parking brake thanks
John
1999 Toyota Tacoma 4x4
Old 03-10-2009, 08:40 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: how do i tighten parking brake
When you crawl under the truck with the wheel chocked and brake off there is a all thread rod, I think it's on the drivers side it will have double nuts on it. Tighten them up to get all the slack out of the cable, but leave just enough so it's relaxed until you set the brakes. You may want some one to sit inside while you do this and try them every so often as you tighten the nuts up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-10-2009, 08:52 PM   #3
oldblue1968chevy
okie dokie thanks
what side of the Y is it on? thanks
John
Old 03-10-2009, 09:08 PM   #4
Andy4639
Old member
Andy4639's Avatar
The rod should be right there on the drivers side under the floor inside the frame rail basicly. My 71 is anyway.
Old 03-10-2009, 09:16 PM   #5
oldblue1968chevy
thannk you
John
Old 03-10-2009, 09:21 PM   #6
cdowns
cdowns's Avatar
have you taken the drums off to check the condition of brake shoe material if any// have you checked to see if the self adjuster star wheel is working properly?
Old 03-10-2009, 09:27 PM   #7
oldblue1968chevy
im pretty stupid wen it comes to brake..but no i hanentt
John
Old 03-10-2009, 09:33 PM   #8
Andy4639
Old member
Andy4639's Avatar
You can't be stupid on something if you've never done it before.
Everybody has to start some place.
If you haven't checked any of the stuff mentioned you need to. Either take it to a shop and get them to or have maybe a friend or someone you trust that knows mechanic's to look with you and show you what you need to look for.
If you have a high school mech shop close by talk to the teacher and see if they will help you.
Old 03-10-2009, 09:39 PM   #9
oldblue1968chevy
ha im in high school
now, ive done fourwheeler drum brakes...i know there quite a bit the same..havent checked the brake shoes..
self adjuster starwheel....is that the lil thing u can adjust the brakes wtih or no..im fellin the answer isgonna be no lol
John
Old 03-10-2009, 09:44 PM   #10
Andy4639
Old member
Andy4639's Avatar
Yes that's the adjuster. Inspect the shoes just as you would your four wheeliers. If there is concern change them.
Now for the cable again. If you get under the truck and the cable is floppy loose then you need to tighten it up good. These old cables will stertch over 40 years.
You may want to try a look in the F&Q section on brakes also.
Old 03-10-2009, 09:46 PM   #11
oldblue1968chevy
its purty floppy lol
John
Old 03-10-2009, 09:50 PM   #12
Andy4639
Old member
Andy4639's Avatar
Tighten it up just enough to get the slack out. I like for my e-pedal to go about half way down.
As long as it holds the truck on a hill is good in nuetral.
Old 03-10-2009, 11:19 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Start with your favorite rust dissolver product first. Those jam nuts are really easy to round off.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 03-11-2009, 03:28 AM   #14
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I assume that you have a 68. The manual states you should pull the brake handle out 4 clicks from the released position. Then tighten the adjuster on the cable until it is snug. This way when you release the e-brake handle the cable will relax enough to keep the brake shoes from dragging on the drums.
Good luck.
PS. I would check the condition of your rear brakes first and then adjust the star wheel first before adjusting the parking brakes.
oldiron is offline   Reply With Quote
Old 03-11-2009, 08:28 AM   #15
truckdude239
truckdude239's Avatar
i second checking your brakes also
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-11-2009, 09:40 AM   #16
nightmare
nightmare's Avatar
Thats funny. When I had my truck inspected last year, the person said that it had to hold the truck still while in drive at 1500 rpms. Of course I'm in Texas, so that may just be a state thing.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-11-2009, 07:26 PM   #17
oldblue1968chevy
okay wat do i do if its tightened all the way up lol
John
Old 03-11-2009, 07:33 PM   #18
Sinister
Between Trucks...
Sinister's Avatar
You'll need a new cable if the old one's too stretched.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-11-2009, 07:43 PM   #19
oldblue1968chevy
dang...bout how much they gonna run
John
Old 03-11-2009, 07:49 PM   #20
Sinister
Between Trucks...
Sinister's Avatar
About $17 + shipping...
Beat it to fit,
