I have a homemade alternator bracket,can anyone tell me if i can replace with something else?
...this the only photo i have!! ![]()
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-10-2009 at 09:20 PM. |
![]() Join Date: Jan 2009
Re: Alternator Bracket
from the photo it dosen't look homemade, it looks like mine
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
Grandpa in the rustmobile...
dont think thats homade..i want 1 like that thoo it nice
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Old member
That is the correct brace, why do you want another one?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
who me, cause mines not like that..its real big and on the other side....id post a pic but im too lazy lol im goin to bed fellas
Well,i've changed alternator 5/6 times(due to the 1wire to the original) & its gettin weak. i tighten the belt tight as can be & it seems like it won't last long,so i wanna get 1 b4 it play out.
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
its all about the +6 inches
that's possibly an aftermarket chromed one?
The stock one which looks like that (minus the chrome) should work fine. |
Old member
Yeper's the chrome ones don't hold up to well. Can you take it off and go by a machine shop and have one made.
Restoration Virgin!
I have one available here (2nd pic down) if you are interested!...
http://67-72chevytrucks.com/vboard/s...d.php?t=296740
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 03-10-2009 at 10:07 PM. |
![]() Join Date: Dec 2008
To be honest with you the alt bracket is one of the last things in that engine compartment I would be worried about. Fuel pump mounted to the heater box unless the tank is in the wiper cowl isn't installed anywhere near the correct location (electric pumps are supposed to be lower then the tank) let alone the heat from the headers soaking into it. I would also look into the oil dip stick as it looks like it used to have a bolt going to a manifold bolt that would be incorrect for a small block and give incorrect readings.
But as far as the alt bracket goes that other then chrome is correct and in the correct location. What brand of alt are you getting? Also as for the belt slipping I would say that is a pulley alinement issue.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it Last edited by pumpgas; 03-10-2009 at 10:34 PM. |
Old member
Man...you got a good eye. It's weird how so many people can look at a picture and see nothing.
I actually was refering to the bottom bracket,not the chrome one on top! sorry guys
#13 |
Old member
Know wonder I didn't see all that other stuff then, I can't even see the buttom bracket!!
#14 | |
dipstick? im sure this truck has alot of incorrect stuff about it. Im not a mechanic so if it runs,i run it! when it does'nt ....I PAY!! thanks though!!
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-11-2009 at 02:09 AM. |
#15 | |
#16 |
Here is a quick pic of what it is supposed to look like.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
#17 |
Restoration Virgin!
not sure if you looked at what I have, but the pic 'pumpgas' posted is what I have available...sorry for any confusion!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#18 |
It's a catastrophic success.
![]() Join Date: Jan 2003
With headers I think you have to use a bracket like this.
http://hotrodchrome.com/alternatorbrackets.html |
#19 | |
![]() Quote:
This is what it looks like!! ...thanks guys!
#20 |
69 GMC of DOOM
mines the stock one and i have headers... workes fine as long as you use short valve covers...i put tall ones on my engine and the bracket didnt like it much
#21 |
Here is a nice shot of what I used to have on my truck. Stock lower and slightly modded upper (took 2 and made 1).
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it Last edited by pumpgas; 03-12-2009 at 06:16 AM. |
#22 |
Old member
Here is mine, it's factory as far as I know.
#23 |
Dont know the years on this, but some of the older motors didnt have holes on the face of the heads and the backets bolted off the exaust manifold.
#24 |
Old member
That's correct. I don't know years either but good point.
#25 |
My 67 283 is that way. Its hard to find driver side bracket for It.
