Old 03-10-2009, 09:41 PM   #1
cobrajet21
cobrajet21's Avatar
coil spring installation
I'm having an awful hard time putting thes front springs in. where does the end of the top of the spring go in relation to that D shaped thing in the crossmember. These are 1 1/2" lowering springs. Every time i think i have them in i tighten the nut on the lower ball joint but i can still move the spring around on the bottom and the top pops out. i'm bout ready to tear up something. i've never done this before and just don't know what the i'm doin.
cobrajet21 is offline   Reply With Quote
Old 03-10-2009, 09:51 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: coil spring installation
Dont worry too much about where the spring sits in the top during the install process. If you get the spring set into the lower control arm properly (only goes in one way) the top wont have an option but to be in properly. Good luck.
--Josh
Old 03-10-2009, 09:59 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they normally rattle around like that at full unload. Bolting up the shock will help lessen that if I remember right
Old 03-10-2009, 10:09 PM   #4
Andy4639
Old member
Andy4639's Avatar
That's what I remember too! Once the spring is in, start tightening everything up and put the floor jack under the a-arm and jack it up enough to install the shock it will get better.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-10-2009, 10:26 PM   #5
pumpgas
pumpgas's Avatar
FWIW when I did just a 1" drop spring and 2 1/2" spindles I was able to lift the lower arm into position by hand. So I would have to say that a 1 1/2" spring is going to be a little shorter and possible be a little loose until you get weight on it. Just make sure to get the lower part of the spring in the correct location (small divit in lower A-arm) and you should be golden for the top.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
