03-10-2009, 11:40 PM | #1 |
Rear View Mirror
Anyone know If I can put a 70 rear view mirror in a 72 cab? I am out of town right now, I found an 70 NOS mirror, bracket, and cover, and can't look at my cab. But I was thinking I could just drill a hole and install. And then do away with the glass mounted rear view mirror. Anybody done this before?
03-11-2009, 12:28 AM | #2 |
Old member
Re: Rear View Mirror
Be very carefull doing this. That drill get's hung and up through the roof it will go! Yes it can be done. Just be very ,very carefull.
03-11-2009, 12:38 AM | #3 |
Thanks, Andy4639. Good tip!!
03-11-2009, 01:48 AM | #4 |
Old member
I posted this one a little while before you did this thread. Not the same ? but same idea's almost. I have the roof mount and going to see when I get the mirror if I can get it to fit the mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=332838
03-11-2009, 02:34 AM | #5 |
resident oilfield trash
I am using a windshield mount and shaving my roof mount. LOL
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
03-11-2009, 11:27 AM | #6 |
I'd suggest putting a length of rubber hose over the drill bit as a stop so your bit can only go through the panel. Also make sure that the screws are short enough that they don't dimple the roof out.
03-11-2009, 11:39 AM | #7 |
Thanks Mr48Chev. Good idea! Any idea how much space is between the roof panels??
