Old 03-11-2009, 12:14 AM   #1
smn69
Questions on grounding and brakes
Finally in the process of putting things back together and I have two questions: First - I bought a grounding strap replacement kit and it has 6 straps in it. Where do they all go? Here is what I can come up with - bottom of cab to frame, firewall to back of engine, core support to frame, I am guessing bed to frame (but where), and engine to frame? Where would the last one go?
Next question - I did a front disc brake conversion and have a new master cylinder to hook up. The old lines are not bent to the right places so I cut them off about 6 inches above the frame and I am going to bend some new lines. The question is - on the back of the proportioning valve is a larger fitting (threaded hole for a fitting) and on the front portion of the valve there are two smaller fittings (threaded holes, one on the bottom and one below the black button) how do I plumb the Master (pictures would be a big help) and what size fittings and steel tubing do I need? I have a bender and flairing tool. Thanks in advance for any and all help. This is a great site!
smn69 is offline   Reply With Quote
Old 03-11-2009, 02:04 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Questions on grounding and brakes
Maybe it's a extra. I can only come up with 5 also.
Frame to
CAB
BED
RADAITOR SUPPORT
MOTOR
MOTOR to CAB
I maybe wrong but didn't they come with 2 straps from motor to cab. For some reason I'm thinking that and don't know why!
Sorry can't help you on the brakes. I can get pictures though tomorrow maybe of my 71 stuff.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-11-2009, 07:39 AM   #3
70GMCer
70GMCer's Avatar
Mine had 2 straps from the back of the engine on each side to the cab firewall.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-11-2009, 07:58 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
here's a few threads regarding ground strap locations....hope these help...
http://67-72chevytrucks.com/vboard/s...d.php?t=153283
http://67-72chevytrucks.com/vboard/s...d.php?t=280727
http://67-72chevytrucks.com/vboard/s...d.php?t=290003
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-11-2009, 11:36 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of threads that might answer your brake questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=306775
http://67-72chevytrucks.com/vboard/s....php?p=3178819
LockDoc
Leon
Old 03-12-2009, 02:14 PM   #6
Andy4639
Old member
Andy4639's Avatar
Here is the master cycinder on my 71 with disc's up front.
The buttom front is for the front disc and the rear is for the drums.
Old 03-12-2009, 02:25 PM   #7
smn69
Thanks all, My questions were answered. Great site!
