Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-11-2009, 12:22 AM   #1
Captainfab
60-66 Nut
'60-'66 Suburban/Panel gas filler assembly
Here is the perfect way to add a filler door to the side of you box for your rear mounted gas tank. This is an original gas filler door and fill tube assemnly from a Suburban/ Panel. The filler door section has been abrasive blasted and primed with 2 coats of quality epoxy primer. The fill tube has also been abrasive blasted and powder coated satin black.
I would like to get $95.00 for this setup, plus shipping. This may seem a little high, but when you consider the work that has went into this so far, it isn't that bad.
Old 03-11-2009, 12:24 AM   #2
Captainfab
60-66 Nut
Re: '60-'66 Suburban/Panel gas filler assembly
More pics.....
Old 03-11-2009, 02:14 PM   #3
joe231
joe231's Avatar
do you have a suburban tank? or pics of one?
CHEVY ONLY
Old 03-11-2009, 11:23 PM   #4
Captainfab
60-66 Nut
I don't have an extra tank, however I do have the one under my '66 Suburban that I can take a pic of. Is there something specific you are interested in?
Old 03-12-2009, 07:50 AM   #5
joe231
joe231's Avatar
i was wondering about how low it hung, how it attaches to the frame, the routing of the filler, and will it fit a truck frame?
CHEVY ONLY
Old 03-12-2009, 11:10 PM   #6
Captainfab
60-66 Nut
The Suburban/Panel gas tank is essentially the same as the '69-'72 Blazer tank. The biggest difference is that the Suburban/Panel tank has a good sized haif-round notch out of it to accomodate the spare tire. I'm not positive, but I think it may be slightly shallower also. The filler is the same as far as I know, and it would fit a pickup frame just like the Blazer tank. I can get you some pics and measurements on Saturday.
Old 03-13-2009, 05:46 PM   #7
padresag
I do have a couple out of the trruck if you want a picture of one
ron
padresag is offline   Reply With Quote
Old 03-13-2009, 05:49 PM   #8
joe231
joe231's Avatar
Thanks John.....
Ron,
That would be great!!
CHEVY ONLY
Old 03-13-2009, 06:15 PM   #9
padresag
send a pm with your email address and I will send them to you later today
ron
Old 03-15-2009, 04:27 PM   #10
joe231
joe231's Avatar
John
I'm interested in these....
got another question..................
do you think this would interfere with the factory body side trim on our '66? would the factory trim need to be modified?
did the panels have trim like the trucks?
i'm not sure of the position of the door in relation to the trim.
CHEVY ONLY
Old 03-15-2009, 10:59 PM   #11
Captainfab
60-66 Nut
Joe
Unfortunately the filler door is right where the Custom Cab trim is on the pickups. I've looked at this myself, and figured I could just cut the trim and carefully finish the ends just like the factory did.
Old 03-15-2009, 11:50 PM   #12
joe231
joe231's Avatar
so you would have a short piece on the filler door?
CHEVY ONLY
Old 03-16-2009, 12:45 AM   #13
Captainfab
60-66 Nut
Yes....or maybe both....I don't remember. I'll have to measure it tomorrow.
Old 03-18-2009, 01:19 AM   #14
Captainfab
60-66 Nut
I did some measuring today Joe. I'm not sure how this would work with the CC trim. Both pieces will be on the door, and the upper one will be aprox centered on the gap at the top.
Old 03-18-2009, 09:18 AM   #15
joe231
joe231's Avatar
that sucks.
CHEVY ONLY
Old 04-03-2009, 11:42 PM   #16
Captainfab
60-66 Nut
Ttt
Old 04-15-2009, 12:23 PM   #17
Captainfab
60-66 Nut
Bump.....
Old 04-27-2009, 04:39 PM   #18
Apache63
1# Drobmember in Germany
Apache63's Avatar
Originally Posted by Captainfab View Post
Bump.....
is it still for sale??
iŽll take it !!!
Apache63 is offline   Reply With Quote
Old 04-27-2009, 11:10 PM   #19
Captainfab
60-66 Nut
iŽll take it !!!
Yes I still have it. I'll send you a PM to arrange payment and shipping.
Old 04-30-2009, 07:59 AM   #20
duallyjams
duallyjams's Avatar
I just went to a show and seen a long bed with this set up and now I just seen this sale add to realize I snoozed for the second time today on a good deal.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-02-2009, 04:59 PM   #21
Captainfab
60-66 Nut
SOLD To Apache63
Thanks Pat
