Old 03-11-2009, 03:10 AM   #1
Cookie
Cookie's Avatar
steering column question
Hey guys i have a dumb question i have a 1986 jimmy with a tilt column well for the problem. The other day i got in it and tried to start it.The ignition would not leave the lock position i pulled the wheel to either side and still wouldnt realease well after about 30 minutes of screwing with it i got it to turn over and its been that way ever since. i won't even put it in the lock position anymore if i do ill be sitting there for awhile trying to get it out. i was wondering if theres an easy fix for this problem or what caused it so suddenly....By the way the only way i found to get the ignition is to move it to accessory then use alot of force to get it to the run position
Thanks in advance for any help
http://i60.photobucket.com/albums/h3...101/img110.jpgMy 98 Trans Am Ls1 6speed trans am's new motorhttp://i60.photobucket.com/albums/h3/jeath101/067.jpg http://i60.photobucket.com/albums/h3/jeath101/018.jpg 1986 gmc jimmy 350/sm465 with 33's
1983 Chevrolet K20 SM465 6.2 diesel with 305,000 miles,gm8 turbo, 4:11s and 14ff
Cookie is offline   Reply With Quote
Old 03-11-2009, 07:17 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: steering column question
If you have two keys for your truck, look at them both and see if they look just a like, some times you will get a bad place in your key and it will not work right.
Now if it looks ok they you have a bad ignition swich and you will have to get a new one and the bad news is it's a pane to change out.
Let us know what happens.
Trav
tvblazer78 is offline   Reply With Quote
