My other Love
What would cause a power steering belt to go inside out?
i have been helping a friend work on his 1978 k20. It has a 350 and everyonce and once and a while his power steering belt will be in the same spot but it will be completely flipped. It is one of the wierdest things i have ever seen. Everything seems to be lined up. But it just disides to this everyonce and a while. anyone know what the heck is going on?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Whats this wire for?....
I knew a guy with a caprice that did the same thing even with a new belt. Try a new belt, or adjust the tension. If that doesn't work, then you are were we ended up.
Kyle ![]() '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
My other Love
brand new belt and it been tightened, loosened you name it
I'm back with 2nd truck!
bent pulley(s)??
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Sounds like either the pulleys are warped and/or aren't alligned correctly.
Scott Shelbourne |
You get what you pay for
![]() Join Date: Dec 1999
If the power steering pump pulley is not lined up right, it's rollover time. I know because when I first installed my headers and removed the AC, mine did the same thing. I had to use a spacer behind the bracket to make everything line up right. Lay a straight edge across the pulleys and check it. I bet the pump bracket is out of wack.
Mike 1985 Chevy C-10 |
swerve: is there anything you don't know? You are the man!
Yeah lots I don't know, but I do a very good job of hiding it.
swerve:
Ha! too funny! I know what you mean, other than online, I know the answer to the caramilk question... Well, not realy but i'll do my best! kyle
