454 MAKES IT ROAR
Help with oil pan removal.............
Can someone tell me what this is and more importantly how do I move it out of the way to remove my oil pan?...I'm doing this job right now and the pan gets hung up on this thing, can anyone help?
If I undo the bolt i'm pointing at will that remove it. ![]() ![]() ![]() ![]() Thanks in advance.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
![]() Join Date: Jan 2009
Re: Help with oil pan removal.............
the thing you are catching on is the oil pump pickup. the bolt you are pointing to is the oil pump bolt, remove it and the oil pump and pickup should come off
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
454 MAKES IT ROAR
Your the man...americanmusc1e. I was sitting wondering how long it would be before I got a reply so I can get back out there and get this thing done.
You guys are the best and so is our board>>>>>
![]() Join Date: Sep 2007
when you remove the oil pump I believe theres a teflon washer sleeve that will break and youll have to replace it but theyre like 3 bucks and always available at the parts store
1967custom |
there should b no need to remove the oil pump to get the pan off// once the pump is removed then you've got the distributor issues down the road on reassembly
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-11-2009 at 10:55 AM. |
Between Trucks...
X2. Did you lift the motor up?
Beat it to fit, Paint it to match... ![]() |
The Older Generation
![]() LockDoc
Active Member
You should be able to pull the pan without taking off the oil pump or the pick up and tube.
See if rotating the crank to get the crank arms up and out of the way will help or take out the center motor mount bolts and jack the engine up a couple of inches - slide a block of wood in between the motor mount and frame to leave the motor up while you change your pan
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() Join Date: Jul 2007
Before you jack up the engine take the fan shroud loose or the fan will hang up on it but yes if you haven't already taken the motor mounts loose and raised it a couple of inches do so.
Dropping the oil pump won't upset the distributor on a Chev small block as the distributor gear drives off the cam and the oil pump shaft fits in the bottom of the distributor. Where you might run into a problem at reassembly is getting the oil pump shaft to bit back up in the slot in the distributor drive gear. That might take a bit of effort to get it in the right position. From reading your first question this old auto shop teacher thinks that it would be prudent for you to head to the local book store and pick up a copy of "How to rebuild your small block Chevrolet" as a reference guide. |
454 MAKES IT ROAR
DOH!!! I removed it....I only just cleared up my tools and came in and saw all these other replies. Leon I tried pulling that pick up off first but it was not for moving and at that time I did not know if it even was supposed to come off...Dam! and jacking up the engine was not an option either as the truck is on wheel ramps and axle stands so I could remove the Tranny. Thanks all you guy for chiming in on this, seems I was a bit to impatient, Michael can you post a link maybe of a parts store that would have that Teflon sleeve, I doubt i'll find that here in the UK.
By the way I wanted to show you all what was laying in the bottom of the pan....I hope there is nothing important in this bent and broken junk. ![]() ![]() Thanks for all the replies and help.
#11 | |
Shane Live life like there isn't going to be a tomorrow.....Because tomorrow doesn't exist! ![]() ![]() |
#12 | |
#13 |
Restoration Virgin!
uh-oh!!!!....That doesn't look good at all....ummmmm....does the engine run okay??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#14 |
looks like there are parts of pushrod and maybe valve locks from previous problems???? Or current problems??? Was the motor supposed to be fresh? Pan does not look like it was....
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#15 | |
454 MAKES IT ROAR
![]() Geoff, 71super the motor was running fine just a bit tappety I only had tranny probs hence all this extra work since thats all been removed and i've got the access to everything else....hopefully it's the remainders of old probs cause my wallet can only handle one rebuild at a time. I am wondering while the oil pump is out should I buy a new one, or can they be reconditioned?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-11-2009 at 03:30 PM. |
#16 |
Restoration Virgin!
The tapping could be many things......hopefully just an exhaust leak...you got headers??....I think you can buy oil pumps....what engine do you have in it??...Check summit racing(will they ship to the UK??).....if you have trouble getting one shipped, I'll order for you and send it from here....
EDIT...looks like you got a 454....does the oil pump look like this???http://www.kmjent.com/cart/product.php?productid=963
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 03-11-2009 at 03:50 PM. |
#17 |
I would just get on NAPA online or CSK online. Its a real common part to replace and found at just about any auto parts store, I didnt see you were in the uk. Wouldnt they have it wherever you got your oil pan gasket? Sorry I couldnt help you out more
http://www.napaonline.com/masterpage...te+Shaft+Guide part #SEP22443343 on NAPA online this looks like its for a multi pack but I bet if you call theyll ship you a single one, looks like you might need some other parts also???
1967custom Last edited by michael bustamante; 03-11-2009 at 03:57 PM. |
#18 |
454 MAKES IT ROAR
That's kind of you Geoff, it has Hooker headers and a 454, think I will take the oportunity to replace the pump since it's been removed.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-11-2009 at 03:57 PM. |
#19 | |
454 MAKES IT ROAR
Thanks Michael you have helped, I usually buy my parts from Wes at Classic Heatrbeat or ClassicParts, costs a bloody fortune by the time I add shipping and a customs charge this end, but that's where i'll go for the new pan gasket.
#20 |
Gone to greener pastures
![]() Join Date: May 2007
A new oil pump can be had for $20-30, American.
An oil pump "kit" which has the pump. pick up tube, pump drive, etc. costs about $65, American, maybe a tad more, but certainly not outrageous. Those are "here" prices. I don't know about overseas shipping, customs, etc. As a side note, when we (my son & I) built the engine for my boat, the guy at the machine shop said we should tack the pick up tube to the pump using Ni welding rod to guarantee it didn't vibrate loose. His suggestion; install the pump and pick up with the pick up way too low & Then put the oil pan into place to push the pick up tube up. Lift the pan off and raise the pick up about 1/2" & then tack it. There is a slight chance of arcing across the crank & bearings, so I always take a marker & "index" the pump & pick up tube and do the tack weld on the bench. Lastly, for whatever it's worth, the machine shop where I learned this has had tons of race car engines come out of that shop. The racers keep going back. And, I've done some other engines after the boat & always did the same thing.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 03-11-2009 at 04:10 PM. |
#21 |
Old member
These look like lifters.
Surely this is from a old motor problem. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#22 |
454 MAKES IT ROAR
Man I hope so!!
#23 |
![]() Join Date: Jul 2004
Looks like a plastic sleeve from the oil pump shaft, some teeth from plastic coated timing gear and some remains of a push rod. Tap the pickup screen on the pump, bet you will find some more stuff in there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#24 |
I can Just about guarantee it's from an earlier problem or your motor wouldn't be running at all...
![]() Glad to see you got it disassembled. LockDoc
#25 |
72 Chevelle Club
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
