03-11-2009, 11:28 AM | #1 |
72 cab mounts which to use?
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=115
those or http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=32 i have nothing of my old mounts left.. i either had to break them or bend them up since they rusted to the truck... so i just pitched the old square metal that came with them.. so i was wondering what would be the better route?? im thinking the more expensive one is the stuff i need...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
03-11-2009, 11:45 AM | #2 |
Under Construction
Re: 72 cab mounts which to use?
the only diff seems to be poly vs. rubber, and no mounting hardware or mounting hardware.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-11-2009, 11:48 AM | #3 |
The Older Generation
This is just personal experience, nothing scientific to back it up... Unless you are building a drag truck or will be using it off road most of the time I would not use the Poly mount bushings. The Poly mount bushings are solid, (no give to them) and the rubber mount bushings are soft. The poly mount bushings transfer a lot of the road vibrations to the cab where the rubber ones don't. I know the Poly's look cool and they are cheaper but they just don't do what cab mount bushings are supposed to do. Just my 2¢ worth LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-11-2009 at 11:49 AM. |
03-11-2009, 11:54 AM | #4 |
Under Construction
very good advice Leon.
03-11-2009, 02:57 PM | #5 |
Junior Member
Yep. Just like the Lock Doc said.
03-11-2009, 03:56 PM | #6 |
Thanks guys. I was about to buy poly myself. What you said makes a lot of sense.
Man those things are pricy!!!!!!!!!!! |
03-11-2009, 09:19 PM | #7 |
truckintexas thats what i was thinking.. i was thinking use the 60 some dollar ones but then i looked at it then the one for 150 or whatever gives you the square metal piece.. so i was wonderin but ya thanks guys im gonna go the expensive route i dont want no road vibrations in the cab i wanna smooth ride
03-11-2009, 10:07 PM | #8 |
These are the ones we put on my wife's truck, nice kit for only $60.
http://www.classicparts.com/1967-72-...info/35%2D145/
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
03-11-2009, 10:13 PM | #9 |
I put the rubber one's from LMC on my truck... look original and have some "give" to them...
I did use poly bushings on my tranny mount and leaf bushings though..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-11-2009, 11:43 PM | #10 |
tim do some price checking. I think I have seen these things from more than one vendor at better prices than $150.
I see powell72 gave you a link. Also, It seems as if Early Classic Enterprices sells good stuff. And I know Brothers has them at $60-$70 LOL |
03-11-2009, 11:57 PM | #11 |
I had to change the cab on my 71project 4X4 as the guy I got it from did alot of off road with the truck and he had changed the mounts to poly. When I got the truck I noticed that the rear cab mounts were coming through the floor and had demoed the floor from using the poly mounts. go with rubber!
03-12-2009, 01:58 AM | #12 |
Recovering 67-72 Addict
It depends upon what your intended use is. On my '73 Camaro fun car I ended up using solid aluminum and I was amazed at the increased handling that change made with just a slight increase in road vibration/feel. On the shortbed that I am putting together now, I am trying all poly.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
