03-11-2009, 11:39 AM | #1 |
Bent Custom and Performance Back-half
Here's a couple sneak peak shots of a back-half we are working on. Everything is designed in house. From what I see and have learned over the years is why take something that isn't broke and try to fix it. These mid 60's trucks have *****en rear suspensions. All you need to do is improve upon it. I've redesigned my own rails and suspension mounting points so you can have the proper look and ride. I took the factory trailing arms which I might add are cool looking to start with. I then reinforced modified and added some look. Let me know what you think? I will have more pics of completion in the next couple weeks.
03-11-2009, 02:31 PM | #2 |
Re: Bent Custom and Performance Back-half
nice... looks really good.
03-11-2009, 03:21 PM | #3 |
WOW!
your work blows me away!!! are those stock arms reinforced or complete customs? Love the sexy curves of the back half
CHEVY ONLY |
03-11-2009, 05:57 PM | #4 |
looks great.
03-11-2009, 10:45 PM | #5 |
03-12-2009, 12:38 AM | #6 |
Those are gonna look so good when mounted..I was already leaning towards trailing arms for my c20 conversion and this settles it. I've been considering fabing my own with a built in 2" drop and pinion correction for a 3" drop spring. Is the crossmember also stock modified.
03-12-2009, 12:42 AM | #7 |
That looks like really good work
70 SWB STEPSIDE 70 BLAZER 09 challenger |
03-12-2009, 08:59 AM | #8 | |
CHEVY ONLY |
03-12-2009, 10:55 AM | #9 | |
03-12-2009, 11:25 AM | #10 |
In.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-12-2009, 12:55 PM | #11 |
What dimension did you end up with after boxing and capping the trailing arms W x H
03-12-2009, 03:43 PM | #12 |
The dimensions are still stock hole and mounting wise. The top and bottom plates are about 120thou. and the back was just capped. So hight is probable just about a 1/4 more than stock.
03-12-2009, 07:21 PM | #13 |
chevy only
Nice very nice
CHEVY ONLY... Nothin Else ! |
03-12-2009, 09:41 PM | #14 |
Bodydropped71
Looks great!! What is the wall thickness of that 2X4 tubing? Also what do you use to bend it?
03-12-2009, 11:00 PM | #15 |
I believe they're just 'capped' or boxed factory trailing arms.
03-12-2009, 11:02 PM | #16 | |
The frame started out as .125 flat sheet. It's alittle labor intense but it's four sides welded together and then radiused along the edges. It's the only way in my opinion to do a complete backhalf. It's clean simple and all the specifications and design are the way I want it . No guess work. There is still going to be more hand made peaces and I'm not sure if I want to lay the shocks parallel to the ground. |
03-12-2009, 11:21 PM | #17 |
Nice to see you over here. Looks sick. You would give these guys a heart attack if you show them the good stuff.
Mike Redpath |
03-13-2009, 12:04 AM | #18 | |
03-13-2009, 01:56 AM | #19 |
I want a heart attack.
If you can find it cheaper, I can fix it! |
03-13-2009, 03:28 AM | #20 |
me too lol.
03-13-2009, 08:40 AM | #21 |
Happy to be here
Oooh, you have more pics like this? You know we want more.
03-13-2009, 11:14 AM | #22 |
Yeah...Dont be a Fab tease.
03-13-2009, 09:51 PM | #23 |
Since Mark has not shown the way, here ya go. Besides a car builder, he is a plumbing specialist.
http://www.bentcustomandperformance.com/
Mike Redpath |
03-13-2009, 10:04 PM | #24 |
Happy to be here
WOW! Very impressive...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-13-2009 at 10:04 PM. |
03-13-2009, 10:31 PM | #25 |
PROJECT 7DEUCE
Wow!!!!!!!!!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
