Tubular contol arms
Is there an advantage to running these over stock? Suspension is my next step after I clean the frame all up and por-15 everything. I need to replace the coils and figured id replace those with stock and put 2.5" drop spindles on but got to searching on here about the control arms and really didnt see anything as far as quality for one over the other. Most was just personal preference.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. Last edited by monte0185; 03-11-2009 at 04:49 PM. |
I wish I was a cowboy
![]() Join Date: Apr 2008
Re: Tubular contol arms
I have tubulars on my rig only because I needed to get 1/2T arms (I have a 3/4T truck) to take advantage of 1/2T brakes, spindles, etc. I would say the advantage is, in order of actual value:
1) Looks 2) Improved geometry for severe drops, and a very far distant #3: 3) suspension performance Theoretically, tubular control arms hold their precise shape in even the most demanding handling situations, but that's mostly non-sense in my opinion, stock arms do just fine. The geometry superiority in most tubular a-arms is that you can run a deeper spring drop (read: bags) without that horrible negative camber problem - because most vendors sell their arms with a camber improved upper arm design for dropped rigs. I wouldn't do it if I already had good arms.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). Last edited by kcjones; 03-11-2009 at 04:59 PM. |
They give a bit more ground clearance on top of looking good and having improved geometry for alignment.
I am a Referee of life.
I think the strength thing is overvalued on these.It's a truck,you're not gonna be doing much(if any) canyon carving with it anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Also, If you are going to run 15" wheels, the tubular arms eliminate the possible wheel/control arm interference concern when running drop spindles.
71 Cheyenne SWB |
Who all has decent sets of them?
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
