Does anyone know where I can get my factory tach calibrated. It reads correct at idle but after that it is about 1000rpm over actual rpm. I have installed a HEI dist. would that be affecting it?
------------------ 69-C10 LWB
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
Binder Rep
did the tach come from a 6 cyl truck?
I don't know I bought the whole instrument pannel at a swap meet. If it is can it be recalibrated?
These tachs are notoriously inaccurate. There is a screw on the back where you can adjust it. HEI will have some effect, but most of them are not accurate with points either.
------------------ Tim
Tim |
You can calibrate any factory tach, 6 or 8 cylinder tach with the calibration screw on the back of the tach. You will need another tach to compare to when you adjusting it.
I recalibrated my factory 6cyl tach against an aftermarket tach, on my 71 with HEI & V8. Works perfect. ------------------
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
this is the tach adjustment screw....
![]() ------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm [This message has been edited by bigvinnie (edited May 15, 2002).] [This message has been edited by bigvinnie (edited May 15, 2002).] [This message has been edited by bigvinnie (edited May 15, 2002).]
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
