Old 03-11-2009, 06:06 PM   #1
sams60gmc
sams60gmc's Avatar
changing coils?
so i'm gonna swap out my rear springs for my new jeep springs tonight and i just wanted to ask and see what the best way to go about it is. i have a jack and jackstands. any help would be great thanks guys!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 03-11-2009, 06:57 PM   #2
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Re: changing coils?
Check out the suspension forum on this board
http://67-72chevytrucks.com/vboard/f...splay.php?f=25
You're doing right by asking first.
If this is done incorrectly it can be dangerous.
Here's an old post about front springs on my 69, has some good points about spring removal
http://67-72chevytrucks.com/vboard/s...d.php?t=263423
I just jacked the frame off the axle and unbolted the spring but I'm sure others will chime in
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 03-11-2009, 07:08 PM   #3
kizer
Its Deja Vu time again
kizer's Avatar
Re: changing coils?
What I did when I changed out my coils so I could paint everything.
I put a floor jack under the axle and gave it a lift. After I had my frame as high as I wanted I put the stands under it and then I slowly loosened the coil bolts. Later I lowered the floor jack which of course took the pressure off the coils and my frame was up in the air.
When I put the coils back in I did the same thing, but I kept very good attention on how high I jacked up the axle since I was going to start lifting the frame up since the coils push on the frame.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-11-2009, 07:08 PM   #4
joe231
joe231's Avatar
Re: changing coils?
support the frame in front of the rear axle(after it straightens out), with your stands, pull your wheels and shocks. make sure the suspension is at full droop.....if not raise the stands so it is. use a floor jack to support your differential and remove the springs.
I cut my springs in 3 pieces to make easier access to the rusty bolts......but that is just me
good luck
kiser, we posted at the same time
CHEVY ONLY
Old 03-12-2009, 12:33 AM   #5
sams60gmc
sams60gmc's Avatar
Re: changing coils?
Thanks for the help guys, my buddy and i swapped them out today, went super smooth. Here is the end result.
Old 03-12-2009, 12:42 AM   #6
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Re: changing coils?
Lookin good man, just gotta get some smaller rubber now to really lay it down.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 03-12-2009, 08:03 AM   #7
joe231
joe231's Avatar
Re: changing coils?
looks good!!
CHEVY ONLY
