03-11-2009, 06:43 PM | #1 |
Can you get coil overs for trailing arms??
My brother told me that you could get coil overs for your trailing arms a couple of years back....I have never seen them so think he is looney. hahaha.
he has a 66 and I have a 67. Is he right and if so where can you get them?? Thanks
If your not living for something, your dieing for nothing... |
03-11-2009, 07:18 PM | #2 |
I am a Referee of life.
Re: Can you get coil overs for trailing arms??
You can get them(sorry I don't remember where) but IIRC you have to install a new crossmember.The original shock mounts don't have enough strength to hold them.I remember reading an install article a couple years or so ago in one of the truck mags(CCT or CT).Night look thrru their ads and call.Could be CPP?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-11-2009, 07:18 PM | #3 |
summit speedway motors jegs all sell coilovers //you cant use stock shock absorber mounts for coilovers they will break in short order// you'd need to fabricate mounts both top and bottom maybe a crossmember too// just measure up what you need and order the proper length coilovers that you need for your ride highth
03-11-2009, 07:57 PM | #4 |
Old Skool Club
All they are, is an overload shock with a coil spring, right?
In the street rod world, they are much more of the suspension than what they would be on these trucks. I'm thinking that you want to replace your coils and shocks with the coil-overs, right? I guess I'm missing something in wanting to do that, but my preference would be AirLift airbags inside the coils, but I don't plan on needing additional load capacity. ....different strokes...
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-11-2009, 08:00 PM | #5 |
I have done coilovers on a couple of of this generation truck. Jegs sells a nice qa1 kit. Be fore warned you can't get the truck super low. You need to mount the upper crossmember as high as possible to get the truck to a decent ride height.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-11-2009, 09:20 PM | #6 |
Old member
There was a kit a few years ago that was sold it mounted the top of the coils on the outside of frame. The bottom was sandwiched between the axle pad and trailing arms with the u-bolts. The lower part of the shock was on the end behind the arm. Pretty cool setup I thought just never could afford it. It even said you could do away with the factory coils.
03-11-2009, 09:50 PM | #7 |
I think that kit was made by hot rods from hell.
03-11-2009, 09:59 PM | #8 |
I got a set of coil overs at AUTOZONE quite a while back!!!! They bolted right up!!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD Last edited by Chevymann1968; 03-11-2009 at 10:00 PM. |
03-11-2009, 10:52 PM | #9 |
Anybody has a pic,I'm trying to figure out what you guys are talking about?
If it ain't a chevy,I don't want it |
03-11-2009, 11:09 PM | #10 |
Coilover shocks!!!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
03-11-2009, 11:35 PM | #11 |
There's more than one way to go about it so it depends on what you're willing to spend. This is the 'kit' Andy4639 was describing . . ...
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-11-2009 at 11:43 PM. |
03-12-2009, 01:01 AM | #12 |
I have a set in my 68, bolt in worked great.
03-12-2009, 01:28 AM | #13 |
Just ask for them at any parts store.
I just put a set on my Coronet Station wagon.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
03-12-2009, 07:27 AM | #14 |
This type of kit is what I use. You can get it adjustable or fixed dampening. If you are planning on racing get the adjustable setup. These are usually mounted behind the axle.
03-12-2009, 07:41 AM | #15 |
Two different animals are being brought into the discussion.The Auto parts store ones are actually a coil over overload shock(used for heavy duty stuff like towing).The true coil over is actually a suspension part with a shock and spring designed to carry the weight.The AS coilovers are not heavy enough to support the whole weight of the truck (at least not for normal use).
03-20-2009, 06:33 AM | #16 |
Where can I get the kit Andy4639 is talking about and where can I get the kit djracer is talking about??
03-20-2009, 06:43 AM | #17 |
Old member
Here is the link for the kit Scoti sent me. I'm ordering the brackets only. I'm just going to move my shocks out here for now. Later I may buy the coilovers. Thanks again.
http://www.restoretrucks.com/Rear-Co...9&search_text=
03-20-2009, 07:17 AM | #18 |
Jegs sell the one I posted.
03-20-2009, 02:23 PM | #19 | |
"Trucks with Class"
They look so good you would want to run a glass bed floor, just so people could see them. lol Plus you have to run lowering blocks to get over 2" drop. You can buy new lowered springs, premium shocks & even a shock relocator kit for about $300. Last edited by PICKMUP; 03-20-2009 at 02:27 PM. |
03-20-2009, 03:05 PM | #20 |
The 71 C10 SWB I bought last year has coilovers mounted to stock shock mounts.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
03-20-2009, 03:05 PM | #21 |
Old member
Back when I was thinking about them they said you could take the factory coils out from under the truck too. Their claim was the kit would make the truck handle better being the shocks and coils outside the frame rails which would make since. It would give the balance of the truck better in a curve for sure with everything being outside the frame rails.
I just think having my shocks moved will help mine a lot.
03-20-2009, 10:20 PM | #22 |
I spoke w/CPP way back when they did offer this 'kit' but it wouldn't work for me because they recommended it be used for only 'weekend warriors' (you COULD NOT carry a stock payload capacity w/this set-up) plus as mentioned it didn't offer much drop vs. the cost (easy enough to tweak).
I too considered getting the brackets by themselves for future possibilities . . ....
03-20-2009, 10:50 PM | #23 |
i saw some on this guys 68 drag truck at the hot august nights show.
03-21-2009, 10:08 AM | #24 | |
It`s like the difference between air shocks and air ride.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-21-2009 at 10:09 AM. |
03-21-2009, 10:20 AM | #25 |
Old member
I'm thinking about making a set of them myself here at work with the scrap metal we have. I'm going to get some measurements this weekend on the truck. See what I can come up with.
