Old 03-11-2009, 07:06 PM   #1
pat123
Pat
pat123's Avatar
LMC Inner Rocker Question
Is the outer floor section the inner rocker and the inner rocker like a slip on type deal in lmc's catalogue?
Thanks Pat
pat123 is offline   Reply With Quote
Old 03-11-2009, 09:14 PM   #2
tim21391
tim21391's Avatar
Re: LMC Inner Rocker Question
the outer floor piece has the inner rocker already attached.. you fit the outer rocker over it and mount it the outer rocker has a slot that the outer floor /inner rocker fits into.... check out my build thread.... i used the outer floor on both sides
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-11-2009, 09:15 PM   #3
tim21391
tim21391's Avatar
Old 03-11-2009, 11:47 PM   #4
pat123
Pat
pat123's Avatar
why does the outer rocker have bolt holes but the out floor dosent?
Old 03-12-2009, 01:12 PM   #5
tim21391
tim21391's Avatar
what do u mean? are you talking about mine??? those holes are for spot welds if your talking about mine...
Old 03-12-2009, 03:16 PM   #6
craig24671
craig24671's Avatar
those are not slip on pieces. you have to cut out the bad and weld in the new pieces
craig24671 is offline   Reply With Quote
Old 03-12-2009, 07:17 PM   #7
tim21391
tim21391's Avatar
slip on stuff is just like a band aid it just covers the rust.. the rust is still there and i know it will come back to you in the long run and haunt you.. i would take time and $ and get the ones u cut out and replace..just my .02cents
Old 03-12-2009, 08:41 PM   #8
pat123
Pat
pat123's Avatar
i know what slip ons are. i guess i should be more clear. the inner rocker and outer floor look different. i know the outer floor has more to it but it dosent have the holes like the innner rocker, and theirs some other stuff in the pic. so thats why im a little confused.
thanks
Old 03-12-2009, 11:59 PM   #9
tim21391
tim21391's Avatar
oh i see what your saying... ya those holes i think are for those slip on stuff since like the slip on floor support bolts to the inner rocker.. or at least the one i took off on my truck did.. im going to weld up the holes anyways.. less chance of water to get trapped and rust... i hate rust.. but yea thats what i think the holes are there for.. the outer floor piece is the way i would go..it doenst have to look good at the welds either because it will be covered up by carpet
