adjustable panhard bar?
i plan on making my own adjustable panhard bar, but need to know the length from this point to this piont. if someone that has one can measure it for me it would be very appreciated.
below is an early classic bar that i used as a pic referance so you know what i am talking about |
Re: adjustable panhard bar?
Rather than take another persons design maybe, pull centerline of your truck and then you will find the magical number.
![]() Join Date: Dec 2008
I don't think Early classics "Designed the panhard bar" Unfortunately they took it from someone, who took it from someone, who...well you get the point.
ruggs;Rather than take another persons design maybe, pull centerline of your truck and then you will find the magical number
because i cant get to my truck right now and it doesnt currently have a panhard bar. plus i am not copying someone elses exactly, my mount brackets are going to be different cuz i already have mounting tabs, 3" lowering blocks and longer u bolts. i just need a measurement so i can make the bar itself Last edited by project 67 sub; 03-11-2009 at 09:22 PM. |
Old member
Easy guy's,
![]() The adjustable bar is not what I call adjustable, well not once you install it anyway. I have the one pictured and it's great but the word adjustable is loosley fitting for it. The only way you can adjust it is to take it off. I can get a measurment in the morning for you, I'm at work tonight but can grab it when I get home. project 67 sub, I hope you make yours a real adjustable one. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
thanks Andy4639. yah i dont know yet if im going to make it a real adjustable one yet but i might. right know its static drop about 9" in the rear, and the stock panhard bar was running uphill and pulling the diff. to the drivers side so i gotta make a new one cuz im on a very limited budget right now and cant buy one, but i already have the tube to build it, and the 1/4" plate for the tabs.
Old member
I'll grab it in the morning. I 'm off tomorrow night so I'll be up most of the day.
ok cool
Old member
It not that big of a deal I guess it's just when I saw the adjustable I thought they meant while installed. Once you put it in you shouldn't ever need to move it I guess.
Old member
I just measured mine 33 1/2 ".
It's a catastrophic success.
![]() Join Date: Jan 2003
Do stock come in different sizes? Mine bar is like 24" center to center of bolt hole.
I just realized you are relocating the mounting points??
#13 |
There's no point in making it "adjustable" If you're going to make one just set the truck at your ride level and put one side to the rear end and the other side to the frame and wha la!
Moving the stock plate helps with a large drop, the rod will bottom out unless you move it. I moved mine to the inside of the rail but i have seen them on top of the rails as well. Last edited by mycool72; 03-12-2009 at 10:14 AM. |
#14 |
Old member
Here is mine installed.
#15 |
#16 |
thats how im going to mount mine, but but with my tabs welded to my 3x3x.250 wall steel lowering block
#17 |
project 67 sub,
I didn't mean to upset anyone and wasn't aware that you weren't near your truck. Just intended to say that if you measured centerline of the truck and know the travel of the rear end you can find the measurement. Sorry if I came across wrong....ruggs |
#18 | |
no problem bro. i dont get butt hurt from stuff like that lol. so no biggie. im not trippin.
#19 |
does any body know off hand what size diameter stud that is on the diff. that the panhard bar bolts to?
#20 |
^^^^bump for possible answers
#21 |
Old member
Looks like 5/8" bolt to me. I tried getting it out, and it ant budghing. I will try again later to remove it. Didn't have a lot of time this afternoon.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-14-2009 at 09:41 PM. |
#22 |
thanks Andy4639
3/8" sounds kind of small....oh I just read the tape and it looks more like it says 5/8" or 3/4" |
#23 |
Old member
Yep more like 5/8 I must of fat fingered the keys. I was asleep when I measured it too!
#24 |
haha yah no biggie bro i appreciate it
#25 |
Old member
No problem I think I got a wrench to get it out with tomorrow. I had plan to get it out when I did the rear end work and forgot about it until I got under there to take the measurements for ya! Thanks for reminding me.
