Old 03-11-2009, 09:23 PM   #1
tim21391
tim21391's Avatar
radiator support swap questions
when taking off the radiator support to change it with a non rusted one... can i leave the radiator hooked up still because i really dont feel like wating all the coolant.. could i just put it on top of the engine... i think i got enough hose.... or is that a big no no
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-11-2009, 10:28 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: radiator support swap questions
I would say there's not enough hose plus you would need to remove the fan. I think ultimately you would end up messing up you radiator.
Your best bet is not take any short cuts. (IMO)
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-11-2009, 10:34 PM   #3
westofb
I really hate wet sanding!
westofb's Avatar
I have done this on later model trucks, you should be fine leaving radiator hooked up. I would remove the shroud, might consider the fan too. Put an old rubber floormat between the engine and radiator to protect rad fins, could use a ratchet strap around the rad back to the hood hinges to hold the rad back out of way....just a few ideas, I wouldn't drop the coolant unless I absolutely had too. Good lucl on switching it out!
Jeff
On my 69 there is plenty of room to leave everything on except the shrould, fan is about 5 to 6 inches from radiator.
westofb is offline   Reply With Quote
