'85 Stepside
![]() Join Date: Jan 2006
bump stop
Good buddy LOLIFE99 made these for me. Easy solution to a problem ,works great on those THORBECKE BROS. A-ARMS,thanks Keith
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: bump stop
Looks like that should keep the tires off the inner fenders.
Happy to be here
![]() Join Date: Mar 2000
Re: bump stop
Nice work!
Re: bump stop
Here you go Charlie, (70k52wd),... very easy to make. And easy to change later if you want to go lower.
Blaze-Air
Re: bump stop
To measure, air down to an inch or so from the liner. Then get the measurement at lower plate to cross member?
Re: bump stop
Yep. Get about an inch away from the inner fender. Then measure from the lower control arm bag plate up to the crossmember. That will be the total distance. Subtract the height of the rubber bumpstop. Then give me a measurement of how tall to make the metal base.
Blaze-Air
Re: bump stop
Great, I'll get a number to you asap. I feel like driving without bumpstops, kinda like driving without insurance.
Happy to be here
Re: bump stop
Are you taking orders yet?
Re: bump stop
Let me know if you need some. These are steel, not aluminum.
Happy to be here
Re: bump stop
I probably will need a set when I update the front suspension. Right now I have set of built that bolt to the stock control arm. I don't think they will fit on the ART arms, I know they don't look that good...
Re: bump stop
Get me a height measurement of just the metal base,... and I'll make a couple when I get some free time at work.
Happy to be here
Re: bump stop
Thanks, will do it.
