Old 03-12-2009, 09:04 AM   #1
sick69
sick69's Avatar
rear end widths
So I've been looking at rear end widths and have done a search for the numbers.
The search resulted in ALOT of wheel back spacing Q&A but thats not what I'm looking for.
So here is the question,,,,,
What is the rear diff width on our trucks? I know the 67-69 is approximately 1.5" narrower than the 70-72's.
I've read somewhere the 70-72s are 64 1/8" from wheel mount to wheel mount. Is this correct?
67-69= 62 5/8" ?
70-72= 64 1/8" ?
Just double checking my double checking before I get myself in trouble.
Thanks guys,
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 03-12-2009, 09:43 PM   #2
Tim Christian
Tim Christian's Avatar
Re: rear end widths
I do not have the measurments in front of me but 67-69 is same length and 70-72 is the same length.
Tim Christian is offline   Reply With Quote
Old 03-13-2009, 12:39 AM   #3
sick69
sick69's Avatar
Re: rear end widths
Ok thanks Tim
Can anyone comfirm the numbers above?
70 chevy lwb c10
Old 03-13-2009, 12:55 AM   #4
abadsvt
abadsvt's Avatar
Re: rear end widths
It has been a little while since i did my own investigating but if I am not mistaking the 67-69 rear ends are 56.5" wide from flange to flange and the 70-72 are 58" flange to flange. Hope that helps.
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-13-2009, 03:12 AM   #5
sick69
sick69's Avatar
Re: rear end widths
Do you mean backing plate to backing plate? I'm looking for wheel mounting surface to wheel mounting surface.
70 chevy lwb c10
Old 03-13-2009, 03:27 AM   #6
sick69
sick69's Avatar
Re: rear end widths
This might help,,,,,
70 chevy lwb c10
Old 03-13-2009, 03:33 AM   #7
OARNGESI
OARNGESI's Avatar
Re: rear end widths
Why is the 70 to 72 rearends wider i thought that 1.5 inches is to compensate for disk brakes didnt disks come in 71
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-13-2009, 04:46 AM   #8
sick69
sick69's Avatar
Re: rear end widths
Starting in 71 the trucks came with disk brakes in the front. Not sur why the ealier rear ends are narrower.
Frank
70 chevy lwb c10
Old 03-13-2009, 08:00 PM   #9
clay68c10
clay68c10's Avatar
Re: rear end widths
I think the older rear drums were narrower.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-13-2009, 11:16 PM   #10
ERASER5
ERASER5's Avatar
Re: rear end widths
70 was the change over year for the rear width. Some are wide, some are narrow.
Back to the original question, what is the measurement? I need to change the oil in the truck tomorrow, I'll try to measure my 12 bolt (1970) and the D-60 (1969).
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-14-2009, 12:56 AM   #11
chev-obsession
chev-obsession's Avatar
Re: rear end widths
this is true
chev-obsession is offline   Reply With Quote
Old 03-19-2009, 07:27 PM   #12
coast2coast
coast2coast's Avatar
Re: rear end widths
Anyone come up with confirmed numbers?
coast2coast is offline   Reply With Quote
Old 03-20-2009, 06:11 PM   #13
sick69
sick69's Avatar
Re: rear end widths
I haven't found the answer yet,,,,so I dunno.
Frank
70 chevy lwb c10
Old 03-22-2009, 11:03 PM   #14
ERASER5
ERASER5's Avatar
Re: rear end widths
Here are my numbers. I measured from wheel mount surface to wheel mount surface.
1970 GMC 1/2 ton truck long fleet with leaf springs
64-1/4" Front with 73-87 disc conversion
63-3/4" GM 12 Bolt 1970
62-3/8" Dana 60 1969
I have a 72 also, but the width will not be any narrower than the 70.
You can see that the new disc conversion is only 1/2" wider than the original rear, or 1/4" each side.
The D-60 is almost 2" narrower or 1" each side.
Does this answer you question?
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-23-2009, 08:22 AM   #15
sick69
sick69's Avatar
Re: rear end widths
Yes actually it does. Thank You! The front measurement was never a concern, but those rear end measurements were the numbers I was looking for. I need to be in the 57"-58" range to run a 12" wide wheel and still have it fit in the wheel well.
Thanks again,
Frank
70 chevy lwb c10
Old 03-23-2009, 08:33 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: rear end widths
This is a great thread... add this one to the file.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-23-2009, 04:46 PM   #17
ERASER5
ERASER5's Avatar
Re: rear end widths
No problem. I was researching rear widths as well as a number of other measurements for a swap I am preparing to do. I want it to go smoothly so I am measuring 10 times!
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-23-2009, 04:57 PM   #18
sick69
sick69's Avatar
Re: rear end widths
That 70 12bolt,,,was it a coil spring rear end?
Frank
70 chevy lwb c10
Old 03-23-2009, 08:51 PM   #19
ERASER5
ERASER5's Avatar
Re: rear end widths
"1970 GMC 1/2 ton truck long fleet with leaf springs"
I have not moved enough winter junk to get to the 72 Chevy with coils, but it should be the same as the 70.
By the way, tell Dieselarmy to quit shooting at you! LOL
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
