Old 03-12-2009, 10:24 AM   #1
DMARCUM123
rearend
is a 86 1/2 ton rearend the same width as a 72 i know i have to put the saddles for my coil susp.
DMARCUM123 is offline   Reply With Quote
Old 03-12-2009, 05:07 PM   #2
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: rearend
I can measure mine tonight and tell you if you need. I got an 86 10 bolt in the Garage. At least then you can measure the 72 and make your decision. PM me and let me know if you want me to measure it.
Driveway Dreams is offline   Reply With Quote
Old 03-13-2009, 10:01 PM   #3
DMARCUM123
Re: rearend
ok thanks
Old 03-15-2009, 04:22 PM   #4
DMARCUM123
Re: rearend
does anyone know the width on a 71-72 rearend and on a73 -87 2wd. truck
Old 03-15-2009, 06:17 PM   #5
b00sted
b00sted's Avatar
Re: rearend
I have an 86 C10 10 bolt 5 lug under my 53 without cutting anything.. I am about to pull it out and replace it with a ford 8.8 and disk brakes...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-15-2009, 10:04 PM   #6
Grapdawg
Driven a 72
Grapdawg's Avatar
Re: rearend
I have a 72 with the box off so it would be easy for me to measure. tell me exactly what measurments you need and I will go see.
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 03-15-2009, 10:33 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Re: rearend
Should be the same. I used 73-87 12-bolt axles in my late '70 housing to convert to 5-lug. Same width as 71-72...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
