Hydroboost M/C questions
Ordered a hydroboost unit today and am looking for an aluminum m/c to go with it. I have found one from Pirate Jack that has a 1’’ bore. What is the difference between a 1’’ bore and a 1 1/8’’ bore??? (I know 1/8’’ haha). Should I be looking for a m/c with a 1 1/8’’ bore??? Has anyone run an aluminum m/c from these guys they seem cheap on the price and have good customer service. They also have the alumiunum proportioning valve for disc/disc that I will order.
Any thoughts guys thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
Re: Hydroboost M/C questions
Nothing guys??
Ordered from who?
Link? Mick |
"THE GREEN GOBLIN"
I am guessing these guys--> http://www.piratejack.net/
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
All I really need to know it what is the difference or advantage in running a m/c with a 1 1/8'' bore vs. a 1'' bore.
Yes, that is the correct site I am going to order my m/c and proportioning vavle from
They offer a 1 1/8" bore in different styles...then why use a 1" bore, I suppose the bigger bore would give you more volume
Thanks for the site, nice stuff
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-13-2009 at 02:20 PM. |
Restoration Virgin!
They are close to me!!!....great customer service too....had a leaking prop valve, called them they sent me a new one and told me to return the old one once I get it off....sorry didn't mean to hijack the thread!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
In general...
The larger pistons in front calipers (front fullsize car and truck) require the larger master cylinder. A smaller master cylinder will work, but the larger will work better. If you were using the smaller (aftermarket) dual piston calipers then a smaller master cylinder would be ok. I hope that is enough of an answer. Mick |
Pirate Jacks is the retail site of the company who manufactures our brake components and also many other companies. They are good parts or else we would not sell them. We sell all the same parts a little less than they do but many companies jack the price up considerably higher. Customers tend to think that since they are less expensive that their is something wrong. Not in this case. Many of their products are stamped with some famous names in the industry. We can have our named stamped or etched into the parts but that raises the cost of the part. I would not fear buying anything from Pirate Jacks.
