03-12-2009, 06:09 PM | #1 |
lock ring exhaust bolts?
I am having a hard time finding these lock rings that went on the exhaust manifold blots. Has anyone found where these can be bought or a good replacement for them?
They came off my 72 Chevy Truck 350 V8 stock manifolds. |
03-12-2009, 06:19 PM | #2 |
Old member
Re: lock ring exhaust bolts?
Make you some out of a S/S. Trace them out cut & drill. You can buy the small S/S sheets at LOWES.
03-12-2009, 06:21 PM | #3 |
Unless you want to be authentic you dont need them. Ive put hundreds of them on without them. I replace the bolts with grade 8 bolts & use the original thick washers or new grade 8 washers 7 tighten them down tight.
03-12-2009, 06:29 PM | #4 |
Moderator
You can get them at www.truckandcarshop.com
