Weekend Warrior
Stupid ? - differance between "107" and "109" Models???
Just like the title says - what's the difference between a (CE/CS/KE/KS"107" and a (CE/CS/KE/KS"109") model.
I'm looking at a restoration packet and it is referring to that and I don't see how you can tell that from a VIN or is it on the SPID? Thanks, Andy
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
Re: Stupid ? - differance between "107" and "109" Models???
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
Weekend Warrior
That lists it as "Cowl to Axle Distance" which equates to wheelbase I assume?
107 = SWB (42") 109 = LWB (54"-59") - I don't see how the 59" works out correctly, but the differance between 54" and 42" = 12" which is the same amount of differance between a LWB 127" and SWB 115" = 12" Anybody know where the 59" comes from?
