Old 03-12-2009, 06:36 PM   #1
tjvending
tjvending's Avatar
Show me your powder coating parts
Show me your powdering coating parts, like some ideas for the engine compartment. TJ
tjvending is offline   Reply With Quote
Old 03-13-2009, 12:32 PM   #2
tjvending
tjvending's Avatar
Re: Show me your powder coating parts
Any pictures out there? How would you powder coat bolts? Do the treads have to be cover?
Old 03-13-2009, 02:59 PM   #3
Robert8096
Robert8096's Avatar
I have powder coated bolts on a bike. In the picture below the caliper,disc and a few bolts are done in black, the front forks, caliper bolts were polished then coated clear and the bolts holding the disc to the wheel are done in almost chrome. You will want to bead blast the bolt then tape off the threads. It works well for bolts you don't remove often but will never take repeated removal and forget the ones you want to use an impact on.
http://home.comcast.net/~rthompkins/IMG_0123.JPG
Robert8096 is offline   Reply With Quote
Old 03-13-2009, 03:04 PM   #4
Gray Ghost
Gray Ghost's Avatar
One of our members does great powdercoating work...he should be chiming in shortly.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 03-13-2009, 04:31 PM   #5
oceanview
oceanview's Avatar
Don't powder coat your crank and water pump pulleys what ever you do. Looks great, squeals like a 86 pontiac sunbird with a crappy transmission in the morning going up a steep hill. I powder coated my hood hinges and springs that came out nice
oceanview is offline   Reply With Quote
Old 03-13-2009, 07:30 PM   #6
big_al_71
big_al_71's Avatar
here is a link for you of kevin the member that everyone speaks very highly of him on the quality of his powder coating.....
http://67-72chevytrucks.com/vboard/s...d.php?t=329049
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-13-2009, 08:22 PM   #7
67C10SWB
Here are some shots of my 67 SWB frame and misc. Also a set of wheels I had coated to match the center caps for my other 67. I have been coating small stuff for a while with the starter kit from Eastwood but I'm about to go into business and do some larger stuff and try to make some money and hopefully have some fun. I will post when I get the shop all setup. Mike
67C10SWB is offline   Reply With Quote
Old 03-13-2009, 08:25 PM   #8
67C10SWB
Here are some more.. Mike
Old 03-14-2009, 09:39 AM   #9
Robert8096
Robert8096's Avatar
Never had the problem of squealing belts after coating them. The engine below has a powder coated oil pan, valve covers,air cleaner, intake, pulleys, timing cover. brackets and carb spacer.
Old 03-16-2009, 05:21 PM   #10
tjvending
tjvending's Avatar
Nice job....What's the process for doing the bolts like you did? Is this chrome powder? TJ
Old 03-16-2009, 09:35 PM   #11
67C10SWB
Thanks! Actually these are ARP stainless 12pt bolts from jegs.
Old 03-17-2009, 07:32 AM   #12
Robert8096
Robert8096's Avatar
I bead blast the bolts and degrease them. I then heat them up to 250 degrees for about 15 min to make sure all grease and oil are gone. I usually wire 5 or 6 bolts together and then tape off the threads. Once all that is done I shoot them with the powder of choice.
Here is the ALMOST CHROME power I use. http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT I'm sure others make it but I am a member of their powdercoat club so I get a discount and free shipping.
Old 03-23-2009, 03:57 PM   #13
tjvending
tjvending's Avatar
How about the Hood Hinge? Can you also do powercoat the spring? OR do you have to take it off? TJ
Old 03-23-2009, 04:07 PM   #14
Robert8096
Robert8096's Avatar
Anything that can carry voltage and withstand the curing temp can be powdercoated. There are some who are talented enough to be able to do plastic but I have not gained that skill. It is best to remove the spring and use some sort of method to expand it just enough so you can get complete coverage. I use a threaded rod and capture nuts to expand a spring.
Old 03-23-2009, 04:51 PM   #15
au03z71
au03z71's Avatar
I had my headers hi-temp powdercoated black. They look great against the orange block. I'll get pics up as soon as I can.
au03z71 is offline   Reply With Quote
