Old 03-12-2009, 06:47 PM   #1
centralchevyman
frames
Is there a diference between a 68 gmc 2wd 1/2ton shortbed frame and a 71 chevy 2wd 1/2ton shortbed frame .
centralchevyman is offline   Reply With Quote
Old 03-12-2009, 06:50 PM   #2
craig24671
craig24671's Avatar
Re: frames
I can't guarantee they are exact but I really think they are the same except maybe where the power steering box hooks up may vary a small amount.
craig24671 is offline   Reply With Quote
Old 03-12-2009, 08:03 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: frames
67 was different where the steering box bolts up, I beleive the 68 and newer are the same.
--Josh
Old 03-12-2009, 08:40 PM   #4
Larry S
Larry S's Avatar
Re: frames
some gmcs had leaf springs. Maybe all, I dont know. I do know I had one before with leafs.
Larry S is offline   Reply With Quote
Old 03-12-2009, 10:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: frames
The rear suspention may or may not be the same... most GMC trucks had leafs, most chevys had coils, either could be had either way.
There is a possibility that the 68 does not have the provisions for the power steering box.
The frame material on the 71 is lighter stronger, made of "high strength steel"
otherwise, they should be the same.
Old 03-13-2009, 02:53 AM   #6
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: frames
NO all I have a 72 GMC long bed with coils
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-13-2009, 06:18 AM   #7
Longhorn Man
Re: frames
in 69, coils were standard on GMC 1500 series trucks.
Old 03-13-2009, 05:30 PM   #8
centralchevyman
Re: frames
thanks for the info
