No brake lights with passenger turn signal
I've tried searching but still not sure. All of the lights on the truck work, headlights, sidemarkers, taillights and blinkers. The problem is when I hit the signal to turn right the blinker flashes but my brake lights no longer work on either side. Turn the blinker off and the brake lights come on. This is pretty frustrating, any help will be greatly appreciated.
![]() Join Date: Jul 2004
Re: No brake lights with passenger turn signal
Sounds like a turn signal switch problem to me, I'm pretty sure the brake lights are wired thru the TS switch and something is not making contact in there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Old member
Correct brake lights work through the turn signal's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Jul 2007
Yes to that, Usually the off side brake light will work when you have the signal on but it looks like the contacts are too worn for that.
Switches are relatively easy to get but not fun to change. |
its all about the +6 inches
yep, 100% right, time to replace the turn signal switch.
Odds are, your brake lights aren't working 100% of the time without the turn signal on either. |
had a problem like this on my 72.. happened to be only one screw in the tail light assembly bucket.. where ya need two to have it grounded out perfectly... i had one that ment it didnt have good ground causing this problem on mine.. before you spend money i would check this it was easy find.. almost any bolt went into mine..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
| Bookmarks |
