edelbrock throttle valve corrector
has anyone used on of these? if so how did it work i have a 350c trans with a kick down cable . it is not hooked up but i would like to. if this will not work then what throtttle cable brackets are you using? my engine is a 355 with vortec heads performer intake and carb. thanks for the help. JOE
Re: edelbrock throttle valve corrector
i am wondering the same thing. my truck has a 700-R4 though
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels ![]() 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost ![]() |
BAD BOW-Silverado XST
![]() The bracket works great. Check with www.summitracing.com. I think they have the lowest price for it. Check the end of my cable too. I have finite adjustment too. |
well mine has a hole in the end of it becuase one of the p/o's bolted it to some tin
hey gchemist wht throttle brackets are you running to hold the throttle cable and the tv cable?
so that one bolts to the rear intake bolts. than ksm for the help
i just orderd the summit vertion of both so i will let you know how it works out
well i got them to day the bracket works great.
he TV cable corrector the throttlestuds diamter is to big so you need to drill out the hole in the carbs throttle arm. i was just going to use theold one but it is not long enugh. other then that works fine the summet one uses one of the carb bolts to bolt it down and then has sliding adjusters for the throttle and TV cable. one question i have though what way does the button the the TV cable have to face? or is it keyed?
what parts did you end up with and do you have any pics of the pieces installed? thanks for the help
Parts and more parts
I made a bracket that mounted to the back bolt on the carb's driver's side. To keep it from moving when you accelerated, I welded a pin on it to sit down into the other hole on the carb mounting foot. This bracket has the square hole for the throttle cable and the TV cable from the tranny cut into it, so that I could mount them just like the factory unit. It will not matter how tall the intake is, because this bracket will move with the carb. I used the measurements that would be required to mount each cable to make things fit right. Once I had the right measurements, we tig welded everything and then powder coated the bracket. It is small and smooth with no sliding brackets or screws sticking out of it.
#12 | |
i bought the summit vertion on the TV corrector and the throttle bracket here be pics the cable are not hooked up got to cold and didn't want to freeze any more ![]()
#13 | |
#14 |
finally got it all hooked up and adjusted as best i can get it. i need a new cable though it is barely long enuff with it fully extened and with the bracker mount fully orward and turned around to gine it an extra inch. but all in all the bracket was agood piece i have no idea how i would of been able to use a manifold mounted bracket with my cable and glad i got a carb mount
Tom H.
