Old 03-12-2009, 10:44 PM   #1
Griz1055
402 BB question
Howdy, I posted this on the main page in "engines" but haven't gotten a response. New poster, but have been reading since August. I bought a '69 4x4 last year to fix up and pull my camper. It has a nice 350, but getting up there in miles (100k). I have a newly built 402 sitting in the garage I can have if I want to keep it. I would like BB torque and power, but this engine has closed port heads and high comp pistons. I read that it is built to run all out, all the time (racing?) Just wondering if it would be a good camper puller and occasional street cruiser and mountain expolorer or is it too hi performance for what I want? Also, would I need to run above 91 octane with this set up? Here are the specs I have for it:
Melling Performance cam (22204)
cam lift .296 int .311 exh
valve lift .503 int .529 exh
L35 oval closed chamber heads 400 hp
SRP-BB high performance high compression forged pistons
Casting # 3969854
Chevy Racing manifold
Thanks! Brent
Griz1055 is offline   Reply With Quote
Old 03-12-2009, 10:54 PM   #2
royo
royo's Avatar
Re: 402 BB question
its really going to be a ground pounder and what is the comp ratio. sounds like it will need racing gas
nickle and dime
royo is offline   Reply With Quote
Old 03-12-2009, 11:06 PM   #3
clay68c10
clay68c10's Avatar
Re: 402 BB question
Sounds like a pretty lumpy cam. It might be ok for your usage depending on what rear gears you have. I bet you'll have to run premium with the closed chamber heads, usually they're pretty close to 9:1 with flat-tops and much higher with any kind of dome.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-12-2009, 11:40 PM   #4
68350
68350's Avatar
Re: 402 BB question
Welcome from Butte, MT!! Sorry I cant help with your question.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 03-14-2009, 07:52 AM   #5
dwaite72lnghrn
Re: 402 BB question
I would think the torque would be to low at the bottom end to do a good job of pulling. The cam would make good torque just to high in the rpm range to help your starts and on a hill it would bogg down and probably ping on you. JMO
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-15-2009, 12:10 AM   #6
Griz1055
Re: 402 BB question
It sounds like it isn't going to work for what I need. Thanks for the help, everyone!
Brent
Old 03-15-2009, 01:54 AM   #7
j_cst_10
j_cst_10's Avatar
Re: 402 BB question
Well, the 402 may not work for what you want it to do, but save that engine for a rainy day. Who knows, you may need a truck or car that will remove a fur tree from your property
j_cst_10 is offline   Reply With Quote
