Old 03-13-2009, 03:38 AM   #1
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Bolt in Rack & pinion Found.....
While reading an issue of classic truck magazine, I came across an ad for a direct replacement bolt in front cross member that uses a rack and pinion set up on it and remembering that a few people in the past have inquired about this very same thing in the past and got little to no results I thought I'd post the info I found on here for you.
The following is copied right off their page and posted here for you to read....
Using stock-existing factory holes, this easy-to-install, bolt-in or weld-in IFS kit featuring ‘78-88 front-steer Impala spindles, 12-inch diameter (Impala) rotors, calipers, and balljoints will give you a 5-on-5-inch diameter bolt pattern. The stock crossmember will unbolt and is replaced with a new 2 x 4 x .188-inch wall bolt-in crossmember that holds a ’83-87 T-Bird power rack-and-pinion steering unit. Either a stock, power GM gear-box pump or GM rack pump is compatible to operate the rack. C-channel frame stiffeners, that bolt inside the frame, are also included in the kit. Modifications to the bottom of the steering column will be necessary to connect to the rack spline, or replace it with an ididit column.
The stock 64 1/2-inch front track width is narrowed to 62 1/2-inches with the new IFS kit. The kit features D.O.M. tubing upper-and-lower A-arms (1 1/4-inch dia. X .156-inch wall lower arms and a 1-inch dia. X .156-inch wall upper arm). The aluminum, adjustable coilover shocks with powder coated springs are attached to a three-position upper mount and a two-position lower mount that offers you about 4-inches of movement for the stance you like best!
Dropped spindles, custom track widths, 1-inch diameter sway bar, steering linkage kit and column are just part of the options available.
Here's a pic of it.........
and a link to the page it's on & their homepage
http://jimmeyerracing.com/pu6.html
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-14-2009, 12:04 PM   #2
78-5.3
78-5.3's Avatar
Re: Bolt in Rack & pinion Found.....
wow did i read that correctly over $3500 ??
looks great though and i bet it works even better!!!!
78-5.3 is offline   Reply With Quote
