Old 03-13-2009, 01:18 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Door pins and Bushings, Big Job?
The drivers door sags a little when it is near the latching point. It is wearing the striker pin on the top. How hard is it to replace the pins and bushings? I want it to close like a new door again.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-13-2009, 01:32 PM   #2
vtwinsport
vtwinsport's Avatar
Re: Door pins and Bushings, Big Job?
not that hard. It's easier to remove the door bolts first so the doors are off. Then, get a tqo pound maul/ hammer and tap the bottom side of the hinge pins. You might need a punch to help them along a little but then again your might just pop out, one of mine did just that. Pins and bushings kits are readily available at the parts stores.
Take a piece of chalk and scribe the outside of the hinge position on the door, it will save you lots of time lining up the doors when you re-bolt them.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 03-13-2009, 02:25 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
I have power windows and locks so i dont really want to pull the door off.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-13-2009, 04:05 PM   #4
LBJ
I posted on this a while back. Do a search on LBJ's posts and you should find it. Easy with a Dremel cutoff wheel to cut the shafts in the middle and go from there. No need to remove the hinges or doors. a helper to hold the doors while working is nice though.
LBJ is offline   Reply With Quote
Old 03-13-2009, 04:14 PM   #5
greystoke
I just did this on my 93 this past saturday, it's different than yours because there's a spring but was pretty easy.
greystoke is offline   Reply With Quote
Old 03-13-2009, 06:49 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Got a link? I didnt see it?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-13-2009, 07:23 PM   #7
heavychevy79
Cheyenne Super
heavychevy79's Avatar
I usally have help myself, but I allways thought I could try using the engine hoist hooked to the top of the door, with a little padding around the chain of coarse.
heavychevy79 is offline   Reply With Quote
