Old 03-13-2009, 10:36 PM   #1
Momboy007
What Parts from the Junk Yard will I need?
Hello All,
Reading about all these 4x4 conversions these days has got me really excited about converting my 69 GMC Big Block/400 turbo tranny into a 4x4.
My question is, I am going with the DIY4x4 Kit, what parts should I be gathering from the junkyard? and what Years will work best?
Thanks with any help you can offer
Rick
Momboy007 is offline   Reply With Quote
Old 03-14-2009, 07:10 AM   #2
Re: What Parts from the Junk Yard will I need?
I`d look for a complete donor vehicle.You need a long list.
Old 03-14-2009, 12:19 PM   #3
skchevota
skchevota's Avatar
front axle, ubolt plates Springs? I am not sure if the diy kit comes with ubolts or not, but you will want them new. You will need a t case, and 4x4 tranny, and then decide what you will do in the rear. Dont forget you will need two drive shafts. You will also need to match the front and rear gear ratio. Brake hoses, shocks, t-case shifter engine crossmember.... Thats all i can thinkl of now, i just woke up.....
skchevota is offline   Reply With Quote
Old 03-14-2009, 11:07 PM   #4
shakedown96
shakedown96's Avatar
before you go to the junk yard you should plan out your build from start to finish selecting and reserching components as you go. what will you be doing with the truck when its converted? will you off road? it will you drive it every day? when you have your porpous in mind go from there. build some thing you can aford to finnish and enjoy. let us know and we will help.
shakedown96 is offline   Reply With Quote
Old 03-15-2009, 08:58 AM   #5
FormerMember
  1. 4x4 engine cross member
  2. transmission mount
  3. transmission cross member (if yours won't work)
  4. 4x4 transmission (if not using a divorced transfer case)
  5. transfer case + shifter
  6. front axle
  7. front drive shaft
FormerMember is offline   Reply With Quote
Old 03-15-2009, 09:49 AM   #6
Mudder
Mudder's Avatar
High hump.
Mudder is offline   Reply With Quote
Old 03-15-2009, 04:36 PM   #7
FormerMember
Old 03-19-2009, 09:52 AM   #8
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: What Parts from the Junk Yard will I need?
his truck should be a high hump already if it's a factory big block. i agree with Tim, buy a complete donor truck and save a bunch of time on junkyard trips.since your truck is a 2wd with leaf springs (i assume) pick up anything from 71-87 for the parts and pieces.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-19-2009, 08:25 PM   #9
Momboy007
Hello All,
Thanks so much for all the good info.
My truck currently does have a high hump and leaf springs. So what I am hearing is, and feel free to correct me if I am wrong, is find a donor truck between 69 and 87 and the parts should still fit O.K., correct? Do I need a 3/4 ton, as my current 2wd is a 3/4 ton
Thanks again everyone
Rick
Old 03-19-2009, 08:34 PM   #10
msgross
msgross's Avatar
go with something newer than 69.. you want disc brakes I assume?
add:
power steering box is different,
drag link to axle as well..
If the donor has a front swaybar then it's a ++
The drive shafts will be the hardest to find, might be easier to have something made for the rear...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
